Coolant Change - SailNet Community
post #1 of 7 Old 10-27-2008 Thread Starter
Coolant Change
I have a Yanmar 2GM20F Diesel, and have not changed coolant during the two years that I've owned the boat.
I'm finally about to make amends, but I'm having trouble figuring out the proper procedure: The engine manual doesn't cover it, and the SELOC manual recommends a very complicated procedure involving several flushes with a coolant circuit cleaner (which I'm having trouble finding) before refilling.
Also, both recommend filling with a 50-50 mixture of water and antifreeze, and I've seen several posts claiming this is an old recommendation that should not be followed when using modern antifreezes.
I'd appreciate some educated opinions on both subjects...
Thanks,
Amir
ahalfon is offline
post #2 of 7 Old 10-27-2008
Maine Sail's Avatar
it depends..
It all depends on whether you buy a pre-mixed 50/50 blend, which is much easier, or buy a concentrated gallon which you then dilute with water to 50/50.
If you buy full strength anti-freeze it's best to mix it with distilled water and not tap water. The standard ratio is still 50/50..
You may be confusing RV type antifreeze for the drinking water system which does not get diluted and is used at full strength.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #3 of 7 Old 10-27-2008
I used the premixed long life that is good for iron and aluminum. I have read that using a 50-50 mix straight will cause damage to seals and gaskets. If after draining the antifreeze it looks contaminated I would flush it. I used a flushing liquid I got at the auto parts store.
badsanta is offline
post #4 of 7 Old 10-27-2008 Thread Starter
I was indeed confused by the antifreeze used for the drinking water system (which I also use to winterize the raw water cooling side of the engine - hopefully OK?) Which would you recommend on the fresh side?
Thanks again,
Amir
ahalfon is offline
post #5 of 7 Old 10-27-2008 Thread Starter
BTW, I was referring to products such as the Seafit Engine & Water System Antifreeze sold at West Marine
Thanks,
Amir
ahalfon is offline
post #6 of 7 Old 10-28-2008
Prestone or Peak antifreeze products are fine. Check out ...
Catalina 320 International Association - Coolant Change Procedure – Yanmar 3GM30FC
or Google up "yanmar coolant change".
"There's a wind in my sails that protects and prevails." - "Six Months in a Leaky Boat", Split Enz
sander06 is offline
post #7 of 7 Old 10-28-2008
Maine Sail's Avatar
Thanks again,
Amir
I would recommend either Prestone or Peak because they are always readily available. Furthermore buy it at Pep Boys, Auto Zone, Wal*Mart etc. and you'll always be able to find that brand again.
Personally I would not convert an engine that has been run on regular "green" antifreeze to a Dex Cool product at this point in it's life. Stick with the regular old green stuff, if that's what it had in it, and do an engine flush, and you'll be fine..
Prestone -
Peak -
P.S. The Seafit stuff, if it comes in a windshield washer fluid shaped bottle, should only be used on the raw water side for winterizing. Seafit makes a fresh water side antifreeze (bottle looks like those above) but why pay MUCH more than you have to for engine antifreeze..??
______
Universal 5411 Oil Change saurav16 Gear & Maintenance 10 10-01-2007 07:16 PM
Coolant Question labatt Gear & Maintenance 18 07-21-2007 08:38 AM
Odd coolant leak issue Valiente Gear & Maintenance 12 05-08-2007 12:14 PM
Understanding Apparent Wind Steve Colgate Learning to Sail Articles 0 11-10-2002 07:00 PM
Understanding Apparent Wind Steve Colgate Seamanship Articles 0 11-10-2002 07:00 PM
