How can I lower the mast by hand? - SailNet Community
post #1 of 26 Old 10-28-2008 Thread Starter
99% landlubber, 1% sailor
modul8's Avatar
I'm looking for advice on how to lower my mast by hand
29 tanzer single spreader, on the hard at a marina 350 miles from home.
what tools do I need to bring?? What equipment setup would you recommend for lowering it? HTis is a one time deal.
I'm looking for an easily made tool (with materials I can buy from Lowes or something)
i will have 3 people (including myself) to manhandle the mast.
modul8 is offline
post #2 of 26 Old 10-28-2008
Sea Slacker
The only time we removed a mast by hand from a 23' boat, it was done in a marina while the boat was in the water. They had a kind of a gallows next to the bulkhead - boat would be docked under it, and then a manual hoist would be used to raise the mast.
I dropped the mast on smaller boats - but on a 29' it may be a stretch - it gets pretty heavy by then. In general it is done by disconnecting the forestay, giving some slack to shrouds and slowly increasing backstay length (usually using some sort of a winch). Mast base also has to support that - i.e. have a pivot. if there is no pivot, mast base can be damaged unless the mast is lifted upwards.
YMMV
brak is offline
post #3 of 26 Old 10-28-2008
Safest way is to hire a crane.. As brak says, it's a handful, and while it might be lowered using a 'gin pole' if the mast step is an adequately strong pivot point (unlikely) it's a very risky venture that can go horribly wrong.
Faster is offline
post #4 of 26 Old 10-28-2008
Faster-
The local crane company quoted him $165 / hour with a four-hour minimum. Making a gin pole/a-frame setup is looking pretty good at this point.
Brak's points about the mast base and a hinge point are good ones... it can be done without a hinge point, but it is much more dangerous to do so.
sailingdog is offline
post #5 of 26 Old 10-28-2008
tommays's Avatar
We step are own masts and bigger ones will require a well built gin pole with the right block and tackle to lift the weight easy it could take a 6:1 to make a mast that size easy to handle
The big issue is standing up the GIN POLE in the first place as are pole is 20 feet and it is a handfull to setup with a mast in the way
We have to do it on the water because around here NOBODY will allow land based DIY steping
If you can give some lenth info i can give you a few ideas
After reading your in chicago the 165 X 4 sounds OK for that area , the yards here charge up to 15 dollars a FOOT each way with the bargin being 18 dollars round trip (fall and spring )
Also building a safe ginpole is not going to be CHEEP and if it is a one shot deal may not pay
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #6 of 26 Old 10-28-2008
Faster-
That's pretty harsh... then he needs to do some phoning around. Check into moving companies and outfits that have small truck-mounted "Hyab" type hoists or cranes.. many of them may have the required height at full extension. You don't have to lift a deck stepped mast very high, simply support it at the spreaders while laying it down. Their rates should be more reasonable.
We've hired such rigs in the past for around $100 - 200 to put in masts and launch smaller boats off trailers. The going rate in Vancouver here for mast picking is around $200.
Faster is offline
post #7 of 26 Old 10-28-2008
Faster-
In his other thread, I recommended looking at companies with bucket trucks, since most masts on a 29' boat are light enough that a bucket truck could probably handle it as well.
post #8 of 26 Old 10-28-2008
Mud Hen #69, Mad Hatter
Delirious's Avatar
Have a bridge nearby? I know someone who used to back his Cal 29 up to a rail-road bridge that crossed a nearby creek after removing the backstay and running the topping lift to a spinnaker turning block. He then used a come-along on the bridge to lift the mast slightly and then set it back down on the pulpit/pushpit.
But he was a madman. I'm pretty sure the rail company would frown on the practice if they caught him.
Same guy decided the best way to deal with a rotting duck carcass in the marina was to douse it with gasoline and toss a match on it. He's no longer in our marina.
Best system I've seen involves two similar sized boats, rafted up on either side of you, and using their halyards and winches to lower the mast. That needs a hinged mast step, however, or a whole lot of careful thought and prior lashings at the mast base; 'cause if that sucher kicks out it will kill whoever's in front of it.
Charlie P. Mud Hen 17 #69 Mad Hatter
To travel hopefully is a better thing than to arrive - R.L. Stevenson
I suspect that, if you should go to the end of the world, you would find somebody there going farther . . . - H.D. Thoreau
Delirious is offline
post #9 of 26 Old 10-28-2008
Bad idea...good way to get arrested.
Well, at least it sanitized the corpse... he's a whack job...
This doesn't require a hinged mast step, since you can tie the mast off a bit above the center of gravity/balance point and then you can lower it fairly easily. As long as the tie off point is above the center of gravity of the mast, it won't kick out at all, since it will be kept upright by gravity.
post #10 of 26 Old 10-28-2008 Thread Starter
modul8's Avatar
no hinge, as far as I can tell
No hinge on this step.
I will have 3 people total to bring the mast down.
modul8 is offline
Deck vs. Keel Stepped Masts Envirella Gear & Maintenance 10 11-29-2009 12:06 PM
Deck Stepped Mast or Keel Steeped Mast??? tbeargladd General Discussion (sailing related) 36 11-14-2007 09:07 AM
Yawl Info Needed sailortonyb1 Boat Review and Purchase Forum 5 01-18-2006 05:51 AM
mast raising and lowering divicolouis Gear & Maintenance 5 08-08-2003 11:08 PM
Small Boat Mast Stepping SailNet Gear and Maintenance Articles 0 06-12-2002 09:00 PM
