Old 10-28-2008
recycle is on a distinguished road
Switch to Digital TV
I have an old AC/DC 9 inch color not digital and was wondering if anyone knows if the marine TV antenas that get mounted on the mast will work with the new digital signals coming in 2009? I know I have to get a converter box or replace the tv to a digital tv and hope the antenna is still good.
LUNA
Tartan 3800 #3
East Greenwich, RI
Old 10-28-2008
artbyjody's Avatar
artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
There is no real "HDTV" antenna...those advertised may have amplifiers on them but are just regular tv antennas... You should be fine - I pick up some 10 or so HD channels here with nothing but a coiled piece of cable (and not attached to an antenna)...
-- Jody
S/V "
1983, Barberis Show 38! or
Old 10-28-2008
Francophobe
TheFrog is on a distinguished road
Antennas don't change
The antennas and cabling for digital TV signal (over the air) are the same as for current NTSC signals. I have been using an old antenna at home for years. Digital is much more fussy about signal loss. If you have a poor signal or loss in the antenna wires you will get a blank screen or extremely choppy signal, there is no fuzz.
Obviously the converter box is required.
_________________
"Ventarrón"
Flying Scot # 4964
Golf is an exercise in Scottish pointlessness for people who are no longer able to throw telephone poles at each other.
-Florence King
To get the most from Sailnet, follow the link in
's signature.
Old 10-28-2008
Yes, the antenna should work just fine.
Old 10-28-2008
Great, Now I just need to find a good AC/DC digital tv.
Old 10-28-2008
Some of the smaller ones—16-21" use a wall wart and actually operate at 12VDC... anything bigger will probably require 110VAC.
Old 10-29-2008
Trekka's Avatar
Seasoned Salt
Trekka is on a distinguished road
Here is a 12v powered digital tuner/converter for soon-to-be-obsolete tv's: Artec T3A
With one of the free gov't coupons it costs $10.
Trekka CSY33
Old 10-29-2008
I'd look for a nice little LCD HDTV, since it will probably draw less power than the converter box and your current one, which sounds like one of the small CRT based TVs.
Old 10-29-2008
jjns is on a distinguished road
you will also want to upgrade the cable between TV and antenna. RG6 is the current standard, billed as improved signal transmission by 8x. Always skeptical of those sorts of claims, but just installed an antenna in the attic and used the RG59 for initial set-up/locating of antenna, but when I finish installed it with the RG6, all channels were MUCH clearer and more stations picked up.
Old 10-29-2008
JimsCAL's Avatar
JimsCAL is on a distinguished road
The marine mast-mounted antennas are typically omni-directional amplified units. If you have a solid analog TV signal with yours, you should be fine for digital TV. If it's marginal, you are not going to be happy as the image and sound will freeze and drop out every few seconds. Very annoying. A directional antenna will provide a stronger signal, but these are not usable at anchor when you are swinging.
Electrical Problem - Newbie Not Sure Where to Start wolfmt Gear & Maintenance 32 07-14-2008 09:17 AM
Installing a Automatic Battery Selector Switch artbyjody Gear & Maintenance 24 07-08-2008 07:07 PM
Installing a New Battery Bank Sue & Larry Gear and Maintenance Articles 0 09-26-2002 08:00 PM
