10-29-2008
Is this a ground leak?
I had been out of town for a couple of weeks so I go down to the boat to check it out and I found a residue somewhat like that often found around batter terminals all around the lag bolt that attaches the ground wire to the mast base. I looked around past threads here and found a DC ground leak test procedure posted by sailingdog, so I did those tests and here is what I found:
With the battery selector switch on "1" and the positive cable removed from No. 1 battery, I measured 1.090 volts, 0.908 M ohms, and 0.32 amps.
With the battery selector switch on "2" and the positive cable removed from No.2 battery, I measured 1.105 volts, 0.910 M ohms, and 0.33 amps.
With the battery selector swich on "both" and both positive cables removed I measured 1.085 & 1.080 volts, 0.910 & 0.910 M ohms and 0.31 & 0.31 volts.
I then measured between the ground wire and the mast base and found 200mv +/-25 mv and 19.6 microampss (the miliamp scale read 0.0000).
My boat is a 1976 Pearson 28. It has a keel stepped mast that sits on a cast aluminum base that has a butyl (I assume butyl as it is a very tough black rubbery material) between it and the floor. The ground wire is lag bolted (3/8 x 2 1/2" stainless) through the mast base into the floor. When I removed the lag bot I noticed discoloration and some fouling in the upper half of the bolt. The bottom half was very clean. The ground cable ring connector was completely encrusted with the white residue. When I replaced the bolt I noticed that it would not snug down and left the ground cable loose.
The electrical equipment on my boat is very simple consisting of a VHF radio, knotmeter, depth sounder, navigation and cabin lights and the wiring for an Atomic Four.
There is an AC system that feeds the battery charger and two outlets, but I was unpluged from shore power. All switches were off and the only thing hardwired to the battery is the charger, which was unplugged.
I concluded that I have a DC ground leak and that the white residue formed because of a loose connection.
Does this sound right? And how do I address these problems?
Thanks for listening
John
