Loose Annode - Page 2 - SailNet Community
post #11 of 32 Old 10-31-2008
I don't discuss my member
Fstbttms's Avatar
Originally Posted by SailChick20 View Post
I wonder what dumb*ss put it on backwards.
Prolly a diver.
Fstbttms is offline
post #12 of 32 Old 10-31-2008
fastbttms... you weren't working in the chicago area recently, were you???
sailingdog is offline
post #13 of 32 Old 10-31-2008
Fstbttms's Avatar
No. But that doesn't mean I haven't made some bonehead mistakes in my line of work. But putting a bullet zinc on backwards isn't one of them.
Fstbttms is offline
post #14 of 32 Old 10-31-2008
Good Lord, sometimes I wonder....I swear I do....
Giulietta is offline
post #15 of 32 Old 11-01-2008
Since you are out of the water and have some time...spray the bolts with PB Blaster. Let that soak in, give it some light taps with a hammer. Put on some more PB and let it soak in. PB does work miracles. I've let some frozen bolts sit for a week or more with regular re-soaking with more PB. Give this a try before going to major surgery.
You said you used a screwdriver. If the bolt head is slotted or phillips instead of hex then using a screwdriver doesn't give much leverage. There are right angle screwdrivers for getting into tight spaces. The right angle can give you some leverage to better exert torque on the screw head. After letting the PB loosen things up use the right angle screwdriver.
Good luck
xort is offline
post #16 of 32 Old 11-02-2008
blt2ski's Avatar
I'd also recomend this for info on the BF! I seem to recall him being a bit loose in the anode too!?!?!?!?!?!
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #17 of 32 Old 11-02-2008 Thread Starter
Leap! The net will appear
SailChick20's Avatar
WOW!!! A whole lotta truths in that article!
"Risk more than others think is safe. Care more than others think is wise. Dream more than others think is practical. Expect more than others think is possible. "
~ Cadet Maxim
SailChick20 is offline
post #18 of 32 Old 11-17-2008
Mikelivingstone's Avatar
Dear All,
I don't know if I am too late in asking this question on the shaft anode, like sailchick my shaft anode have a habit of coming loose on the shaft. However in my case they start hitting the hull and damaging it! Why does that happen? I have tried tightening under water to no avail and thus had to remove the anode. The anode does not have severe signs of deterioration, am I doing something wrong? Thanks
Mike
Mikelivingstone is offline
post #19 of 32 Old 11-17-2008
Mike-
Did you use loctite on the threads of the anode?? If not, it could be that vibration is causing it to loosen up.
post #20 of 32 Old 11-17-2008
I have not used loctite but I have used locknuts (the ones with the nylon bushes inside) instead of the nuts supplied with the anode. What I have never done is to hammer it in, is it necessary?
Pros and Cons of Loose Footed Sails scurvy General Discussion (sailing related) 30 11-18-2006 10:12 PM
Tying up loose ends: Sailboat Club practices knots - Villages Daily Sun NewsReader News Feeds 0 06-15-2006 11:15 AM
loose footed or track mainsail soverel28 Gear & Maintenance 5 05-21-2002 04:08 AM
Loose Cutlass Bearing Sue & Larry Gear and Maintenance Articles 0 02-18-2002 07:00 PM
