Loose Annode - Page 3 - SailNet Community
post #21 of 32 Old 11-17-2008
sailortjk1's Avatar
Kristen,
What is the latest?
Were you able to remove it?
I am going to Crowley's tonight after work to tow a friends boat, I could take a quick look if you want. It should not be very difficult to remove.
Courtney is My Hero
sailortjk1 is offline
post #22 of 32 Old 11-17-2008
Yes, generally you do have to tap the zinc halves with a hammer to seat them. Or you could use a c-clamp to squeeze them into place.
Originally Posted by Mikelivingstone View Post
I have not used loctite but I have used locknuts (the ones with the nylon bushes inside) instead of the nuts supplied with the anode. What I have never done is to hammer it in, is it necessary?
sailingdog is offline
post #23 of 32 Old 11-17-2008
Larus Marinus
Idiens's Avatar
Maybe it goes with the anode. All the bullet and egg shaped ones I have fitted to the shaft are a tight fit, so either a tap with a hammer or a squeeze with a clamp is necessary. The important thing is to have a good electrical connection over a large area between anode and shaft.
I don't use loctite or locking nuts, just those provided. They have a race with the anode halves to see which erodes fastest and so are very quickly unmoveable. If the anode ever slipped I would suspect I was using the wrong size for the shaft and would notice that when fitting it.
I get the old anode off the shaft with a hack saw blade down the gap between the anode halves.
Jonathan-Livingston
Idiens is offline
post #24 of 32 Old 11-17-2008
Mikelivingstone's Avatar
Sailing dog and Idiens thanks for your advice, I might have used a 1 inch anode on a 25mm shaft. I'll make sure it's a 25mm anode that I use next.
Thanks
Mike
Mikelivingstone is offline
post #25 of 32 Old 11-24-2008 Thread Starter
Leap! The net will appear
SailChick20's Avatar
Got an email from the Yard today...they noticed my anode issue while winterizing my engine...and can remove/replace for $230. I say...no thanks!
"Risk more than others think is safe. Care more than others think is wise. Dream more than others think is practical. Expect more than others think is possible. "
~ Cadet Maxim
SailChick20 is offline
post #26 of 32 Old 11-24-2008
What, you don't want to give them a quarter of a boat buck... for doing 10 minutes of work??
post #27 of 32 Old 11-24-2008 Thread Starter
Ha, right!..and for a $15 part.
I think I can handle it without the "professionals" gouging my wallet.
~ Cadet Maxim
post #28 of 32 Old 11-24-2008
Owner, Green Bay Packers
Damn!,
There goes the new set of foul weather gear, gear bags, ship's clock, single-malt Scotch, and new Croakie's tjk said we were gonna get in the spring! I was gonna load up the full set of oxy-acetylene torches too, just to make it look good. I can't believe that yard went an low-balled you just to get the work! How the heck are genuine grifters like tjk and I gonna get by? (g)
Wm. F. Buckley, Jr.
sailaway21 is offline
post #29 of 32 Old 11-24-2008
Ok, here we go, we got a real pressure cooker
going here, two down, nobody on, no score,
bottom of the ninth, there's the wind-up and
there it is, a line shot up the middle, look
at him go. This boy can really fly!
He's rounding first and really turning it on
now, he's not letting up at all, he's gonna
try for second; the ball is bobbled out in center,
and here comes the throw, and what a throw!
He's gonna slide in head first, here he comes, he's out!
No, wait, safe--safe at second base, this kid really
makes things happen out there.
Batter steps up to the plate, here's the pitch--
he's going, and what a jump he's got, he's trying
for third, here's the throw, it's in the dirt--
safe at third! Holy cow, stolen base!
He's taking a pretty big lead out there, almost
daring him to try and pick him off. The pitcher
glance over, winds up, and it's bunted, bunted
down the third base line, the suicide squeeze in on!
Here he comes, squeeze play, it's gonna be close,
here's the throw, there's the play at the plate,
holy cow, I think he's gonna make it!
Giulietta is offline
post #30 of 32 Old 11-24-2008
moderate?
camaraderie's Avatar
Meat Loaf...Paradise by the Dashboard Light...Voice of Phil Rizzuto calling the play by lay. Rizzuto WAS the voice of the Yankees and is a Hall of Fame shortstop who played in the 1950's!
Howz that Giu!! That loosen yer anodes??
camaraderie is offline
Pros and Cons of Loose Footed Sails scurvy General Discussion (sailing related) 30 11-18-2006 10:12 PM
Tying up loose ends: Sailboat Club practices knots - Villages Daily Sun NewsReader News Feeds 0 06-15-2006 11:15 AM
loose footed or track mainsail soverel28 Gear & Maintenance 5 05-21-2002 04:08 AM
Loose Cutlass Bearing Sue & Larry Gear and Maintenance Articles 0 02-18-2002 07:00 PM
