Fuel tank corosion - SailNet Community
post #1 of 2 Old 08-22-2002 Thread Starter
Fuel tank corosion
Hi, I just bought a beneteau 38 that has not been used much for the past 2 years. It appears the gas cap is coroded and will not come undone. I actually broke the star wrench trying to open it. Does this happen? What can I do? Thanks for any advice.
kaai2392 is offline
post #2 of 2 Old 08-22-2002
Fuel tank corosion
Your cap should be chrome plated bronze or stainless steel and should not corrode. If it really has try spraying it with WD40, let it soak awhile and use your winch handle to open it. I assume since you said "star wrench" that the winch handle should work. If that doesn''t work, remove the screws and the fill hose and the ground wire and replace it. This is an easy job if you have access to the underside of the deck fill.
Sailmc is offline
Fuel tank problems Lusk Gear & Maintenance 18 01-23-2007 06:17 PM
Sabre 28 Fuel Tank RickFagan Gear & Maintenance 1 10-26-2006 03:08 PM
Holding or fuel tank jeanneau beneteau Myblueheaven Living Aboard 0 02-28-2005 10:35 AM
holding or fuel tank Jeanneau Beneteau Myblueheaven Cruising & Liveaboard Forum 0 02-28-2005 10:34 AM
old diesel fuel capedoryus Gear & Maintenance 1 12-17-2002 08:14 AM
