Old 11-02-2008
bristol321 is on a distinguished road
rudder hardware question
Been looking online for a rudder shoe......anyone now of a distributor of rudder hardware...specifically a rudder shoe?
Old 11-02-2008
Idasailor sells a lot of rudder hardware and may have what you need.
Old 11-02-2008
Tried ida....mostly tiller driven.....can't believe a part like this is so .......hard to find
Old 11-02-2008
Do you have a photo of it?? If you posted a photo of it that might help.
Old 11-02-2008
No luck even with a picture.....all i can do is provide a description...
The rudder rests/pivots upon the keel. The bottom of the keel has a u shape that protrudes outward to catch the rudder foot. This boat has no "rudder shoe" instead it is simply a bronze pin thru bolted in place that the rudder pivots upon. I am looking for the shoe with a pin/sleave/bearing that the rudder would pivot upon.
Old 11-02-2008
AllThumbs's Avatar
midlife crisis member
AllThumbs is on a distinguished road
I am thinking you need to have something made. Doesn't sound too complicated. Gets some measurements and go to a machine shop and get a price. It sounds like simple lathe work. In fact, if you sent me the materials and measurements, I might be able to make it for you. I have a lathe and milling machine.
Building a New Ruuder Armchairprotest Gear & Maintenance 16 12-06-2009 10:15 PM
Rudder Bearing Replacement - C&C 44 jonb Gear & Maintenance 3 05-19-2008 06:51 PM
When a rudder bearing is bad, can it cause a leak? rryan14 Gear & Maintenance 5 05-19-2008 05:17 AM
Catalina 27 rudder teodoro50 Gear & Maintenance 1 11-06-2007 07:27 PM
'nother rudder question mwrohde Gear & Maintenance 9 06-18-2007 10:10 PM
