-   -   AC Bilge Pumps? (http://www.sailnet.com/forums/gear-maintenance/48576-ac-bilge-pumps.html)
SSGreenAnchor 11-02-2008 09:03 PM
AC Bilge Pumps?
I have a liveaboard with no engines and some major leaks. Our bilge pumps are essential to flotation at this point but I'd rather not be married to using DC batteries when we have access to AC all the time.
Do AC bilge pumps exist besides basement style sump pumps?
Does an AC to DC converter do the job in this case?
Does that exist?
thanks,
Rusty
Giulietta 11-02-2008 09:10 PM
AC DC converter is called a transformer..they are found anywhere, from Radio Shack to Wall mart..
I don't know..and AC bilge seems risky....what do you think???
camaraderie 11-02-2008 11:36 PM
merc2dogs 11-03-2008 01:34 AM
Realy doubt they'd make an AC bilge pump that's marketted as such.
They do make a few smaller sump pumps that would work nicely on a boat, had one I used in the basement for a long while, small and compact would fit in a lunchbox, but moved water like crazy.
If you don't have DC on board, go with AC or spend extra on a converter,
A bilge pump is nothing more than a DC sump pump, no difference in design or construction criteria.
Ken
sander06 11-03-2008 07:43 AM
Is there some reason that you're not capable of fixing the leaks in your boat. Kind of fundamental to boat floatation I would think.
sailingdog 11-03-2008 09:23 AM
I'd second trying to reduce the inflow as much as possible, by fixing whatever is leaking. Seems to me that a boat should keep the water out... at least as much as is possible. Also, relying on AC-based pumps seems a bit foolish, since the times when the AC cuts out—storms and the like, are probably when you're most likely to need the pumps most.
TAK 11-03-2008 09:30 AM
Yes, Rule makes a 1500 AC pump.
That said I agree with SD that may not be the most reliable rout to go.
