Old 11-03-2008
Vancouver, BC
anderbra is on a distinguished road
Cool mast steps are a bad idea
A friend tells me that mast steps are a bad idea because hallyards get cought on them.
I'm thinking of placing two folding steps, at the same level, about four feet from the top of the mast, just in case I need to do any prolonged work there in the future.
my questions are:
Should I bother going up the mast just for step installation purposes (of course while there I'll check the conditions of everything else)?
Does anybody with folding mast steps installed share my friend's opinion?
Thank you for any opinions.
SV Strudel, Niagara 31
Not all who wander are lost.
Old 11-03-2008
merc2dogs is on a distinguished road
If it's been a while since the mast has been inspected, I'd make the trip to install and inspect, but if you've recently inspected, take your time and do it at your next inspection trip.
Ken.
Old 11-03-2008
jrd22's Avatar
Courtney the Dancer
I had fixed mast steps for a long time, only had halyards get hung up once or twice and it took about 10 seconds to free them. Definitely a big advantage when you need to go up the stick. I'm sure they create some windage, but folding steps would be minimal. All in all I think they are an advantage.
John
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 11-03-2008
Omatako's Avatar
Omatako will become famous soon enough
On my previous boat I had steps made of 4mm stainless roundbar that have minimal windage and are shaped not too different from a stirrup. I prefer these because when you have to go up the rig in a sea (it happens!) your feet can't slip out of the step as easily. The fold-away ones have a small lip on the outer edge to prevent slipping which IMHO is inadequate.
I had two occasions to go up the mast on that boat whilst I was alone at sea, without the steps I wouldn't have been able to. A pair of track shoes made my feet really snug in the steps and allowed considerable confidence going up the rig without someone belaying me with a halyard. There were a few times when halyards got tangled but the benefits of having steps easily overrides that problem.
I intend putting the same steps on my present boat before any long voyage - I believe them to be essential on a long passage.
Arthur C. Clarke
Old 11-03-2008
Aside from windage, additional weight aloft and catching halyards...all of which can be minimised by choosing the right step design, IMHO, having some mast steps, particularly below the first set of spreaders to the deck and near the mast head are a good idea.
The reason I don't think you really need them all along the mast, is that the places you really need them are where I indicated above. When you're working on the mast head, it is good to have some steps there to help take the weight off of the bosun's chair or climbing harness. They also will let you get up higher to work on the masthead itself, which some climbing solutions don't do.
The reason for having them up to the first spreaders is so that you can climb up quickly to look for things like coral reef heads, which are easier to spot the higher up you are.
Old 11-03-2008
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
Before adding permanent mast steps, I'd consider a Mast Mate.
Jim
s/v Abracadabra
1976 Pearson P30
Old 11-03-2008
camaraderie's Avatar
moderate?
I think mast steps are a waste if you have an alternate way of getting up and down when needed EXCEPT if you are going to be in coral waters where having steps up to the spreaders can help you spot the heads.
Old 11-03-2008
billyruffn's Avatar
billyruffn will become famous soon enough
Mast steps on BR are shown in the photo below. I think they're are preferable to the open-sided type because your footing is much more secure, especially if you have to climb the mast while heeling. The disadvantage is that things can get caught on them, but the solution is pretty easy. Note the "line" running up the outside edge of the steps in the photo. It's a length of 1/2" wide AL bar that's welded to each of the steps.
A year or so before I had this done I tied a small line to each step in the same position the AL bar is in now. The line worked as well as the more permanent solution now in place.
The bar doesn't extend down to the first step on either side as this would have required expensive modifications to the sail cover.
I haven't had anything caught on the steps since we made this simple modification.
Old 11-03-2008
Valiente's Avatar
BF: I've seen this one before. If line alone worked, why may I ask did you weld bar to them? This is one case where I think 5 mm Dyneema would interest me.
Old 11-04-2008
Omatako's Avatar
I guess I should have qualified my above response by saying that mast steps are useful if you're sailing alone or with someone not strong enough to winch you to the top of the mast (my wife).
Things to do other than scoping out coral? Masthead sheaves, radar scanner (I've had a belt jump off more than once), radar reflector, lost halyards, stuck top furler bearing, tricolor/anchor light, there is actually quite a long list.
On my present boat I have Batcars so Mastmate I believe is not an option.
Arthur C. Clarke
Deck vs. Keel Stepped Masts Envirella Gear & Maintenance 10 11-29-2009 11:06 AM
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
ABI Mast Steps waltzingmatilda Gear & Maintenance 24 09-18-2007 09:44 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
Good Lanes and Bad Lanes Brad Read Racing Articles 0 04-25-2001 08:00 PM
