Removing paint from Gelcoat - Page 2 - SailNet Community
 1Likes
post #11 of 18 Old 11-08-2008
On my boat I was able to remove a painted on name just using acetone.
Marc, Westbrook, CT
marcberoz is offline
post #12 of 18 Old 11-08-2008
Marc-
Acetone can easily damage or soften gelcoat if left on for any significant period of time.
sailingdog is offline
post #13 of 18 Old 01-21-2014
Re: Removing paint from Gelcoat
I just purchased new peel and stick name for my boat to replace the faded painted on one. The supplier, who does this proffessionaly, told me to use EZoff oven cleaner to remove the old name and nuetralize with white vinegar afterwards.
Any residual paint can be emoved with rubbing compound.
jaytee is offline
post #14 of 18 Old 01-21-2014
JimsCAL's Avatar
This is a 5+ year old thread. I suspect he got the paint off.
JimsCAL is offline
post #15 of 18 Old 04-14-2014
The Company that I purchased my new "Peel and Stick" name told me to use Easy-Off Oven Cleaner and nuetralize after with White Vinegar.
I hope it works as I plan to do it today.
jaytee is offline
post #16 of 18 Old 04-14-2014
Thank
cardude is offline
post #17 of 18 Old 04-15-2014
Master Mariner
capta's Avatar
Back in the day before decals, the professional sign (name) painters all used Easy Off Oven Cleaner. I do not know of anything better, cheaper or safer for the gel coat. Do make sure it is indeed painted on there, as it's very rare these days.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #18 of 18 Old 04-15-2014
EZ-Off, the traditional product in a bottle NOT the new aerosol cans, was basically lye. Same as drain cleaner, but thickened to stick on vertical surfaces.
Lye is also sold as a paint and varnish stripper in paint stores, often is the active ingredient in purple industrial cleaners.
Yes, it usually works and works well, and since it is an alkali it will eventually soften or damage gelcoat and fiberglass if it is not thoroughly rinsed off, and followed by a mild acid (vinegar) to neutralize it.
But don't be surprised if there is a pale ghost left behind after you get the name paint off. Since that was shading and protecting the gelcoat beneath it, there's usually a brighter shadow left behind, and there's no simple way to remove that, although careful compounding and polishing of the hull may blend it in.
hellosailor is offline
Repairing Gelcoat Cracks and Chips Don Casey Gear and Maintenance Articles 0 11-06-2002 07:00 PM
Recovering the Shine Don Casey Gear and Maintenance Articles 0 08-04-2002 08:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
Removing Old Names Tom Wood Buying a Boat Articles 0 11-05-2000 07:00 PM
Paint the Bottom Yourself Tom Wood Gear and Maintenance Articles 0 03-09-1999 07:00 PM
