11-07-2008
1st verify that indeed you have tinned wire, many marine stores wont even carry it as it is double the price of regular, the difference to you is having your wiring last 20 years instead of 2.
Wire loom is available at most auto parts stores in varying sizes.
Twisting and taping is the sort of repair one does on the roadside with no tools available, it will be the first place for failure to occur. There is no substitute for soldering and shrinking save maybe those special little 1-shot solderable shrink connectors, but at a buck-a-piece you are better to buy a quality soldering gun and a roll of shrink, also the connectors will require a hot flame to solder/shrink which isn't always ideal around things like wood and fiberglass. Having colour coded wires is also a great idea, 5 years from now, if you have to do a repair, it will be a lot easier to pick out the green wire rather than on of the bundle of 6 same coloured wires that disappear under the floorboards. Also, do not use those little plastic "scotch-lock" connectors, even taped or shrunk they will be a source of trouble in less than 12 months. Good luck.
