11-08-2008
ASA and PSIA Instructor
I don't remember my setup on this size boat, if you don't get other opinions, I'd look at boats with similar size mains and see what they have or you should be able to get an idea from whether there is leverage in your current outhaul, if there is a multipart system, then you would need at least similar or more power for the reefing system. If it a grey area, you may not have a lot to lose to set it up for manual use and add the winch if you find you don't get a good set manually.
It's curious the boat doesn't have a reefing setup, or are you converting from roller-reefing?
