White bottom paint - Page 2 - SailNet Community
post #11 of 17 Old 11-11-2008
Bene505—
As I said above, its a teflon-based paint... doesn't have a biocide in it AFAIK. It is designed to be too slippery for marine life to grab a good hold of.
sailingdog is offline
post #12 of 17 Old 11-11-2008
Glad I found Sailnet
Bene505's Avatar
Thanks Dog. Is there a downside to it? (hard to apply? expensive? both maybe?)
(((And will it let me hit 15 knots like Giu?)))
Bene505 is offline
post #13 of 17 Old 11-11-2008
Bene-
No idea... AFAIK, it isn't available in the USA... so that'd be the first downside to it. IIRC, it is made by JOTUN.
post #14 of 17 Old 11-11-2008
After reading a rudder thread here, I checked with Foss Foam and they insist that any boat out of the water, with dark bottom paint, cover the rudder. They suggest white bottom paint. I didn't think to ask them what white bottom paint.
xort is offline
post #15 of 17 Old 11-11-2008
If the Foss Foam rudders are made of epoxy-resin, requiring the rudder being painted white makes sense. Epoxy has a fairly low thermal distortion temperature, and if painted a dark color and exposed to sunlight, can heat up to the point where they will start to deform.
post #16 of 17 Old 11-11-2008
Bene505's Avatar
I have an email into Jotun US. I'm wondering how much more the teflon paint is than regular bottom paint, and if it lasts longer and therefore still cost effective.
I'll post the results when I get them.
Bene505 is offline
post #17 of 17 Old 11-11-2008 Thread Starter
"Sparkie"
j34035's Avatar
I found white VC-17 for E39.99 on the internet. You just cant buy it here. Just looking, the good go-fast paint in the US does not come in white. I have found negative comments on the Vivid and the E-paint both. What I have not heard is how the white VC epoxy works in fresh water. I have heard it is not so easy to apply, but does make a good hard finish that will last. However it is not anitifouling paint, it is made for dry sailing. Maybe just have to stick with the VC-17 bronze. Oh well........ Thanks for all the feedback!!
DD
Doug
Jboat J/37c (new to me Jan 2011); J/22 #1003
j34035 is offline
Confessions of a bottom feeder PracticalSailor Gear and Maintenance Articles 9 06-18-2008 04:33 PM
The Bottom Paint Blues Don Casey Gear and Maintenance Articles 0 06-22-2003 08:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
Bottom Paint Compatibility Dan Dickison Gear and Maintenance Articles 0 01-24-2001 07:00 PM
Paint the Bottom Yourself Tom Wood Gear and Maintenance Articles 0 03-09-1999 07:00 PM
