Gate valves and why we don't use them... - Page 2 - SailNet Community
post #11 of 29 Old 11-10-2008
Alex, not full of crap
werebeagle's Avatar
And you can even have a pet one.
Charlie
Courtney's my Dancing Angel
Where am I, and where's my paddle?
It's not impossible, it just costs more.
Give me ambiguity, or give me something else.
werebeagle is offline
post #12 of 29 Old 11-10-2008
As crocodile Dundee would say Now that's a gate valve.
bubb2 is offline
post #13 of 29 Old 11-10-2008
Owner, Green Bay Packers
Thanks for that link, bubb2. The picture is illustrative of how you can have a three foot diameter gate valve and still allow one man to close it! It can also be noticed how the stem rises up through the wheel as it opens which allows it to be lubricated periodically. The packing in the stuffing box is replaceable and the box itself is adjustable for wear and compression of the packing to prevent leaks.
Here's a non-rising stem model approved by Lloyd's fro marine use.
http://www.johnsonvalves.co.uk/Data/...te%20Valve.pdf
Wm. F. Buckley, Jr.
sailaway21 is offline
post #14 of 29 Old 11-10-2008 Thread Starter
sailboy21's Avatar
How did this thread turn into "Here is the gate valve I use on my 1020 foot ship?"
Anyways. I got another question for you all.
Here are the givens:
6 hours of working time on a tide grid
35-40 degree air temp. Water 42F.
Glass work not possible.
Any use of sealants questionable..
Gatevalve is non functional and stuck open.
Should I:
A: replace it with a standard bronze ball valve being careful not to tweak the mushroom and break its seal
B: Cut down the mushroom. Undo the nut on the mushroom. Carefully thread a Groco seacock on and hope for a good seal. If I do it this way I will leave the current backing plate in place which is glassed wood. One big problem is it is barley the size of the base of the seacock. I also could not thru bolt it at this time.
C: Do nothing and have a boat with an 1 1/4" thruhull that can't be shut for the next 6-8 months until the weather allows for a real haul out and glasswork.
Hmmm. I am leaning heavily to option "A" but these are my choices. I have a 12 foot tide noon in two days so hopefully I will be able to get a spot on the tide grid and get to work. If I miss this next tide window it will be another month before I can try again! Eek...
sailboy21 is offline
post #15 of 29 Old 11-10-2008
Either option 'A' or why not just plumb in a valve after the stuck-open one until permanent repairs can be effected?
Wm. F. Buckley, Jr.
post #16 of 29 Old 11-11-2008
I think adding a second valve is probably your best temporary fix. If you try removing the existing valve and break the seal on the through-hull, you'll have an annoying and persistent leak that will put a strain on your bilge pumps and batteries.
sailingdog is offline
post #17 of 29 Old 11-11-2008 Thread Starter
sailboy21's Avatar
There is no direct path to the bilge where it is so if it did leak the water would end up all over the cabin floor.... ick.... But due to space restrictions it isn't possible to add a second valve. Heck, it is hard enough to get in there and work on the first one. The closest thing to that idea that I though of was to remove the hose barb and cap it. This isn't satisfactory in my mind. I have a nice pair of vice grips that are meant for working on pipe I can use to keep it from moving. Worst case I can pop it off, get some fast cure 5200 and stand there in the rain and rising tide with a heat gun
post #18 of 29 Old 11-11-2008
Either leave it alone then or put a plug in the thru hull from the outside. I'm getting confused here. Are you worried about the gate valve rupturing, with the bonnet popping off and flooding the boat or are you concerned that you've a thru-hull you cannot close if necessary? If the former, then you need to replace it or plug it, period. If the latter, and the rest of the piping between valve and sink is in good condition, you can add another valve anywhere, even under the sink.
Wm. F. Buckley, Jr.
post #19 of 29 Old 11-11-2008 Thread Starter
sailboy21's Avatar
The problem valve: About 4" above is blocked. There is about 6" on either side to work with, and as you can see the area behind the valve quickly tapers off to nothing. This valve is about 12 - 18" below static waterline. The ball valve in front of it is for the holding tank discharge.
I am concerned about having a thru-hull that can't be closed. I also can't winterize the system properly. The sink drain is 1 1/2" exhaust hose that appears to be in good condition, but then it tees off. This is a really tight area. It passes through a bulkhead about 6" after making a 90 degree turn, and then under some cabinetry and then to the sink. The other problem is not being able to winterize the system. I usually pour RV antifreeze into the sink. It does get cold enough to freeze sea water here!
Would life-caulk cure in time? It looks like I am going to be on the grid for about 12 hours. The next high tide isn't high enough to float off. Weather looks like chance of rain. Highs 45 low of 36 Shorepower is available so I could use a space heater if necessary at least inside the hull.
post #20 of 29 Old 11-11-2008
Maine Sail's Avatar
We answered this question last year in another post you made about tide grid & changing of seacocks.
Here's what I wrote last time after calling both 3M and Boat Life..
I called both 3M and BoatLife and spoke with tech support about cure times & launching. I did this because neither site really specifies launch time's or windows before launch and I would like to add this info to my article. Here's what I was told by each..
BoatLife: When I spoke with boat life they very clearly stated to me that a full cure of between five to seven days with Life Caulk is what they recommend before a launch. The tech support guy would not budge on this point even when I told him 3M 4200 and 5200 will finish curing under water. I could not get him to budge on this and he said tack and cure are two different things and cure times are very dependent on ambient temperature. He also stated that the air & hull temp can't drop below 40 degrees during the cure process and must be perfectly clean before application.
3M: I spoke with Tom about 4200, 5200 and 101. He advised against 101 due to it's very long cure time in a short window situation or regular 5200.
As for 3M 4200 & 5200 Fast Cure he stated that while they will still cure under water they don't advise running the boat, as in water movement over the hull, until cure has been completed because it can erode any sort of fillet or seal thus causing a leak and possibly moisture entrapment. I think a slow motor to your dock would not hurt as he was mostly referencing power boat failures.
3M also stated that a 40 degree minimum of both hull and air temp should be adhered to and that the lower the temperature the longer the cure time. The hull must also be bone dry & free and clear of any paint, dirt or oil when you are applying it.
3M's official policy on underwater use is to let them fully cure but this guy was being quite honest. He did say they have seen failures on quick launches that's why he advised NOT moving the boat after launch (no water flow across the hull).
Again, 3M's OFFICIAL LEGAL STATEMENT POLICY IS TO LET IT FULLY CURE BEFORE LAUNCH. I say this because I don't want people running around saying 3M told me it's perfectly OK to launch in one hour even though it probably is if you're smart about it....
______
-Maine Sail / CS-36T
Maine Sail is offline
