Old 11-09-2008
sailboy21's Avatar
sailboy21 is on a distinguished road
Gate valves and why we don't use them...
I know I know... But I haven't had a haulout other than to cradle ship my boat and I still have one gate valve for the galley sink drain. It finally gave up the ghost today. You can turn the handle all you want forever and ever and ever I think the gate is lodged about 1/4 shut but of course there is no way to tell. So now I have to either schedule a haulout ASAP or hope the tides are right to dry out on the grid. Temps are around freezing so I can't do any glass work or painting. What a waste of a haulout...
Let this be a lesson to all you procrastinators!!! I know you are out there...
Replace crappy substandard valves ASAP!!!
Don't wait, DO IT NOW!
Old 11-09-2008
CS271409's Avatar
CS271409 is on a distinguished road
Do I understand correctly from your comments that you are in Alaska but don't haul your boat for the winter?
I changed all my gate valves in my 1978 27 footer this spring. It was a time consuming and fairly expensive venture but worth it in my mind. The gate valves looked brand new when I took them off but I still like the piece of mind I get from proper seacocks. They were in fresh water only.
Wait for Maine Sail to chip in here on this subject... it should only be a few minutes or so. He has an excellent site providing great instructions on how to do this. You shouldn't need to do any painting or fibreglass work but I used some West System epoxy to set my new bedding / backing plates.
Dave S
Georgian Bay, Ontario
Catalina 34 - (formerly CS27) "Good Idea"
Old 11-09-2008
sailboy21's Avatar
Year round sailing in Alaska... What sucks is I had plans (always got plans...) to replace all the mushrooms and backing plates and install real flanged seacocks for every thru-hull. Now I get to just band-aid the problem and save it for later by putting a new NPT ball valve on the old mushroom.
Old 11-09-2008
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
At least it isn't on an engine cooling intake. Had a fellow sail club member recently tell me about the time a gate valve failed on a boat he was on, on the engine raw water intake. IIRC, the alternator bracket failed, the alternator fell off and broke off the raw water intake's gate valve's handle. They jury-rigged an alternator bracket (they were "at sea"), but did not realize that when the gate valve's handle was broken off, the gate fell closed. Luckily, it turns out impellers are usually tougher than we give them credit for.
Jim
s/v Abracadabra
1976 Pearson P30
Old 11-09-2008
xort has a spectacular aura about xort has a spectacular aura about xort has a spectacular aura about
"proper" seacocks are better but not perfect! i have several that are stuck, frozen. and they are in extremely difficult areas to reach.
you MUST excersize all valves
Old 11-09-2008
Owner, Green Bay Packers
sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice
There is nothing inherently wrong with using gate valves on a boat as a sea ****. The problem arises with the quality and design of valve used. What is commonly seen is a brass valve suitable for home use. There are high quality gate valves available in a variety of materials and construction methods. and they'll work just fine properly installed.
Small boat sea cocks serve their purpose well if maintained. Ball valves work easily but sometimes too easily if they're mounted to something that is subject to vibration and movement, like a boat. They can be either closed or opened inadvertently. Most of them commonly found are of no better construction than the lowly gate valve from the hardware store. Being a ball valve does not inherently make it safer...just easier to use.
There are no ships that use the same type sea cocks you'll see on boats; there's no effective way of operating them absent power. Gate valves are used almost exclusively, with the telescoping thread type being most common. Butterfly valves are often used but not for sea cocks. Butterflys are commonly power driven and suffer the same weakness that most, other than gate valves, suffer; a potential inability to close by manpower alone. Those long stems you see on gate valves are what gives them their mechanical advantage. Thus one man can easily open or close a valve that may be serving a 36" diameter pipe.
Here's a site I found buy simply googling gate valves: http://www.velan.com/products/pdfs/v...603-99-web.pdf
Further research will reveal the tremendous variety of suitable gate valves, even for your thru-hulls.
Wm. F. Buckley, Jr.
Old 11-09-2008
countrybumpkin's Avatar
countrybumpkin is on a distinguished road
yep! still trying to figure out the best way to fix my situation. I can sail, but the cooling system is closed for now: http://www.sailnet.com/forums/gear-m...ould-i-do.html
Old 11-09-2008
sailboy21's Avatar
There are several inhearant reasons not to use gate valves where a Teflon seated ball valve is available:
-No definite position indication
-mating surfaces will leak if damaged
-takes a lot longer to open or close
-prone to jam on backseat
-damage from freezing more likely
-more corrosion prone (more wear surfaces)
-more parts involved (more point of failures, as in my case)
Old 11-09-2008
I think you'll find that subs use butterfly valves that are backed up by gate valves. Double valving thru-hulls is common practice on ships. I've never seen a square head **** or a ball valve on any ship..at least in a major piping system.
Wm. F. Buckley, Jr.
Old 11-10-2008
Valiente's Avatar
Someone needs to review the automatic word censoring on a site in which the word for a male chicken is both legitimate and frequent.
