11-10-2008
Yes, going to a ball-bearing sheave organizer will reduce friction.
However, it does depend on what you're using the sheaves for.... If the deck organizers are being used for heavily loaded, primarily static lines, like halyards, you might be better off with sleeve bearing sheaves instead. Ball bearings are better used in dynamic situations, since the ball bearings can distort if left loaded for long periods of time.
