Impeller hrs - Page 2 - SailNet Community
post #11 of 22 Old 11-13-2008
impellar
I have changed my impellars about every 3 years and they always looked just like the new one I replaced it with. But for some reason I just keep on doing it.
justonemoreproject is offline
post #12 of 22 Old 11-13-2008
DrB
Cheap Insurance
As others do, I replace mine once a season (about 6 months). I put about 50 h on the motor each year. I put a new one in in the spring just before launch. Their cheap compared to a tow or a damaged engine.
DrB
DrB is offline
post #13 of 22 Old 08-04-2010
Tweety
hbergold's Avatar
Stay away from blue impellers
Originally Posted by SVCetacea View Post
Try the Globe #075. Defender has them for $34.
I fell for all the nice spec’s that are out there about the blue Globe impellers, but what a fraud. It didn’t last more that 40 hours. Once I friend told me I should stay away from these but I didn’t listen. Know it’s my turn to alert other. I almost fried my engine. I even threw away the other one I bought for replacement. For your safety, stay with the original Yanmar black impellers.
hbergold is offline
post #14 of 22 Old 08-04-2010
Old as Dirt!
svHyLyte's Avatar
100 hours or 12 months, whichever comes first. Running it past the 12 month timeframe is risky. It will fail when you need it most. THey are not expensive and it is easy to do. Just make it part of your oil change maintenance. No big deal.
- CD
Exactly correct. On the other hand, trying to back-wash the bits of a broken impellor vane out of a heat exchanger can be a serious PITA.
FWIW...
svHyLyte is offline
post #15 of 22 Old 08-04-2010
Maine Sail's Avatar
Bingo!!!! LOTS of bad luck with Globe and lots of others with failures too...
Just a heads up..
I've tried the Globe impellers but found them very problematic. Below are some quotes and photos from another forum. My failures were the center hub spinning free of the blue impeller. This was a tough one to trouble shoot as it looked fine. The next one the tolerances were off ever so slightly and she would not "prime".
Images courtesy P. Shed
Originally Posted by P. Shed
I was removing the sea water impeller from a M25 this morning . I do it each fall after haul out. To my surprise the impeller was cracked on every vane. This impeller was new this spring. The one I took out was a rubber type and was still like new but was old so changed it out . This is a # 815 . I would say there are only 35 hours on this impeller.
I will be taking it back tomorrow. Also going back to rubber type (black)
Sorry the pics are not the best
Images courtesy Bottomscraper:
Originally Posted by Bottomscraper
I have been using the Globe Blue Run-Dry™ Impellers for years and I have been very happy with them. I usually remove them at the end of the season and they look almost new with a little discoloration. This year every single blade was cracked. I did notice that this year the center appears to be plastic rather than metal like the older ones. Here is a picture of the impeller I removed today after 1 season (about 120 hrs). It has never run dry.
It appears that they have changed materials and that these impellers are now junk. I guess I will be going back to the black ones also. Too bad they had a good product. I was considering using their motor mounts but I think I will look elsewhere.
And another:
Originally Posted by Ken J.
I left a dock, must have sucked a bunch of EG up while warming the engine/untieing lines. Noticed the temp was running 10° hotter than normal, stopped in the middle of the bay (no wind) to investigate. Pulled a significant plug of EG out of the strainer/intake. Reprimed the the pump and restarted the engine. Water flow out the back was not normal. Shut down again and pulled the impeller apart. The pictures show the condition of the Globe impeller. It was less than 3 months old, never run dry. It probably ran 20-25 minutes at less than full water flow and never saw temps above 170°. Not buying the 15 minutes run dry.
Just an FYI that the Globe impellers are NOT all they are CRACKED up to be..
I replace yearly... Engines are 15k my impeller is $16.00 or about the price of a 12 pack of decent beer..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #16 of 22 Old 08-04-2010
tdw
Super Fuzzy Moderator
tdw's Avatar
I'm in the change once a year camp and always keep a couple of the old ones on board just in case. Just seems to make sense, and as Maine says they are not all that expensive.
Does anyone have any experience with those quick change Speedseal impellor covers ? I figure their greatest advantage is that they use a much better, as in reusuable, gasket than those damn paper things.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #17 of 22 Old 08-04-2010
They also make changing the impeller a lot easier, especially if the impeller is in a difficult location, since you don't have to remove all four screws.
sailingdog is offline
post #18 of 22 Old 08-04-2010
tdw
tdw's Avatar
SD,
Reality is , I guess that it would be simple to modify a standard impellor cover to be as easily removeable but you are still stuck with the crappy paper gasket. Thats why I reckon its the gasket and the gasket housing design that makes this thing look the goods.
― Terry Pratchett.
tdw is offline
post #19 of 22 Old 08-04-2010
Send a message via Skype™ to oceanscapt
I change mine yearly and keep the spares. I've yet to see one so bad that I trashed it. I do it more as a PM move than having the impeller go south at the worst possible time.
Some folks pull the plate off a couple times a year for a look-see but I don't think you can get a good look at the impeller condition that way, and by the time you get it out you might as well replace it.
I've yet to replace the cam though.
Capt. Douglas Abbott
USCG/MCA IV/C.I./M.I. 500-ton Oceans
PADI MSDT
oceanscapt is offline
post #20 of 22 Old 08-04-2010
I change mine every 300 hours or 3 years which ever comes first. since I usually put around 100 hours per year it works out pretty good. I used to change every year (100 hrs ) but decided that its just a waste of money, but if it gives you some peace of mind to change every year it may be worth it to you.
Mitch
mitchbrown is offline
Westerbeke 20B Two Impeller change c40eb Gear & Maintenance 5 11-05-2008 07:30 AM
Marine Diesel Engine Hrs turfguy Boat Review and Purchase Forum 13 07-17-2008 06:24 PM
Replacing Impeller ccriders Gear & Maintenance 25 06-29-2008 07:12 PM
Impeller Trick Cruisingdad Gear & Maintenance 17 05-21-2008 04:00 PM
3JH2 Yanmar Impeller RickBowman Pacific Seacraft 2 03-09-2007 06:10 PM
