11-10-2008
Best Looking Moderator
Originally Posted by waltsn
Cruisingdad,
Nice setup.. The numbers of 205 amp hours per day out of a 520 watt panel (ie, 4x 130) are pretty good.
If you dont mind, is this using a MPPT controller? What part of the country was it measured at and what time of year? (assume it was also measured with one of the xantrex charge monitors).
Note - I had posted here earlier about a rule of thumb of .234 amp hours per day per watt. Using this equation would only predict 121 daily amp hours for a 520 watt panel. So Im just trying get another data point...
Yes, I am using a Outback MX 60 MPPT. It calculates the AH it puts out to batts. That was measured in North Texas.
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Are you trying to talk your spouse or family into cruising or sailing? Want to know what it is like, every day? Click here and enjoy: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
