Blogs
User Name
Old 11-10-2008
kwf05001 kwf05001 is offline
kwf05001 is on a distinguished road
best mooring setup
I have been searching through older threads and have found alot of useful info, but not the solution.
I have a through the center bouy and am experiencing the usual problem of the dual pennants getting themselves fouled below the ball and chaffing on the chain. I see two possible fixes:
add a swivel above the ball, bind the two pennants together and add floats OR
make the ball act as a standard ball by hanging a very short length of chain through the ball and a swivel just below and attaching the pennants there
reference maine sails great photo post on what not to do as mooring storm prep
We aren't superstitious, but...
-Lin and Larry Pardey
our rhodes meridian, s/v sugar magnolia:
http://www.flickr.com/photos/25156908@N05/
http://www.myspace.com/seafarer_meridian
Old 11-10-2008
SailingFlorida's Avatar
SailingFlorida SailingFlorida is offline
SailingFlorida is on a distinguished road
Nice looking boat your restoring, hows the restoration going? What year is that boat?
Old 11-12-2008
Leither's Avatar
Leither Leither is offline
Retired and happy
Leither is on a distinguished road
Any chance of a photo of the setup? As someone from the UK, I have to be careful about offering advice sometimes, because things are just that bit different over here. On the face of it, both of the solutions you suggest sound possible, assuming I understand your mooring arrangement correctly.
Your boat looks beautiful. I know that making progress on a very tight budget can be frustrating, but you certainly sound really enthusiastic, which is more than half the battle.
Keep in touch with the SailNet forums, I am sure that there are lots of people out there who would be very interested in your project, and keen to offer advice.
Stuart
Leith (rhymes with teeth) is the port of the City of Edinburgh in Scotland. A Leither is someone who comes from that area.
I must go down to the sea again, to the lonely sea and the sky - I left my shoes and socks there, I wonder if they're dry?
Sponsored Ad
Old 11-13-2008
Maine Sail's Avatar
Maine Sail Maine Sail is online now
Maine Sail is a jewel in the roughMaine Sail is a jewel in the roughMaine Sail is a jewel in the rough
Some rules of thumb..
#1 Big heavy chain gives good caternary effect and prevents shock loading.
#2 Moorings are usually designed at a 2:1 or 3:1 max scope, depending upon local regulations, so this means heavy chain is a must if you want any caternary and protection from shock loading.
#3 Chain wears where the links meet. Anchors are not constant duty but moorings are. Moorings are exposed to wear & link degradation 24/7 365.
#4 The biggest chain, or wire diameter, you can buy will last you the longest.
#5 Galvanized chain adds no real long term benefit as the link wear chews through it rather quickly anyway so self colored chain is fine.
#6 Long link mooing chain is a good option because shackle fit better through it.
#7 You should have a top chain and a bottom chain. the top chain will be lighter than the bottom chain. A good rule of thumb is that the bottom or really heavy chain be 1.5 times max water depth. You will replace the top chain every three to four years depending on your location but bottom chain can last as long as 7-10 if big enough..
#8 Depending on the bottom type you can use: Mud = Mushroom, pyramid or screw. Hard bottoms = Large diameter granite (low and flat is best). Cement is generally considered a bad idea, by just about every municipality that has studied mooring field failures, and many municipalities have banned it's use as it loses a significant amount of weight bellow water and there a re no real "standards". In this vein many have also baned "home made" moorings of engine blocks, cement filled barrels and such. Most require any home made mooring to first be inspected by the local harbor master.
#9 Many municipalities only allow certain approved mooring companies to set, retrieve, inspect and maintain moorings. The anchorage I'm in now has over 1200 boats and they are very, very strict as to what you can and can not do!
Feel free to watch this video and you'll see the types of mooring conditions boats in Maine can deal with in the winter and during Nor' Easters. Most boats up here use the Wayne Hamilton mooring protocol as shown bellow. None of the boats in the video broke free despite a few of them having 15 footers breaking over them. One actually rolled about 80 degrees and popped back up but did not break free.
Please ignore my video skills..
Enjoy...
Why Not to Cut Corners On Your Mooring System (LINK)
Photo Courtesy of Hamilton Marine (LINK)
This is my bottom chain for a 36 footer..
Bellow the ball pendant attachment causes the least amount of problems unless you have multiple floats and the "equator" of your mooring ball sits bellow the surface of the water. If the waist or "equator" of your ball floats above the surface of the water, no matter how many floats you have, it will wrap the ball and then get suck down to the chain as the boat pulls..
______
-Maine Sail
Casco Bay, ME
Boat - CS-36T
Our Sailing Photo Galleries
Old 11-13-2008
mangomadness's Avatar
mangomadness mangomadness is offline
mangomadness is on a distinguished road
Bridle Plate Mooring System | Colligo Marine
I like this bridle mooring system.
I feed my pennants through two "foam noodles" and my lines never wrap. I need to replace noodle once a year.
Old 11-14-2008
what i did for now...
So I did make some changes to my setup:
-ran 15" of chain through the ball with a shackle keeping it from falling through
-below below the ball this chain hangs out only one link and is shackled to a swivel
-the pennants are also shackled to the top of this swivel
-the top chain is connected to the bottom of the swivel (there is also an existing swivel btwn the top and ground chain)
- my pennants are siezed together to about 4' of the bow (one (NE ropes braided) has about a foot of slack when pulling dead astern) just above the thimbles both pennants are fed through a float I got at defender to keep the shackle from drooping and possibly taking a side load
Maine Sail:
You prev. info is most detailed and very much appreciated
I already had what you described when it was installed earlier this year (based in part from reading your posts), but I wanted to add a second pennant and was experiencing the "strangulation" effect b/c of the dumb TC3 ball. hopefully I've resolved that with the above. my mooring is a couple hundred yards from the nearest boat and have approx. a 4:1 scope on a spring tide w/o waves and theres only a 3/4nm fetch at most
do you have a link of that bottom chain on your mantle to calm your nerves during a rough storm? -i would
To the compliments of the boat:
I wish she looked like his: Island Sailing Adventures
but with lots of time, patience and a steady stream of small monetary investments someday she could
oh and she was built in holland in 1962, hull No. 38
Old 11-14-2008
Maine Sail's Avatar
This is good but always be sure to go considerably larger on this swivel than you would on chain. The swivel is THE weak link and will see considerably more wear than any of the chain links. I recommend 7/8 as a bare minimum for a 30-35 footer and 1" for 35-40. Over that they get very, very expensive!
This is good!
This is unecessary and not really such a good idea unless you are a diver or know one. Out of site out of mind is bad when it comes to swivels. One swivel is more than enough unless you are in a river with constantly reversing currents. If this is your situation you will be replacing swivels bi-yearly anyway! A bellow the ball swivel can be inspected by you quite easily and should be.
This is very good. Keeping the shackle in a constant plane is something many moring installer over look let alone boat owners. it is perhaps one of the sigle most important aspects to prevent bellow the ball pendant chafe. The flaots should have enough floatation to keep the shackle in the same position whether the boat is pulling on the mooring or not.
My mooring guy buys it surplus from the USCG.. I honestly don't know where to find it at a reasonable cost. He cuts the chain into usable sections and cuts out wear areas.
Sweet boat!
______
-Maine Sail
Casco Bay, ME
Boat - CS-36T
Old 11-14-2008
thanks for the approval
that gives me some serious confidence coming from you, can't wait to get home so I can see that video
b/c of my large scope I can actually pull that lower swivel up fairly easily, the boat is in a suedo-river (niantic river in CT), it swings around quite frequently, I was already considering removing it, but didn't have the energy that day...
I'm going to take your advice and upgrade my swivel size as soon as the present ones start to show wear and order from hamilton since theirs spec. US made and the price premium seems to indicate higher quality
when I get to it I'll send you some pics of what happened to one of my pennants in just a few weeks
Old 11-14-2008
Maine Sail's Avatar
Please do I would really appreciate it!
______
-Maine Sail
Casco Bay, ME
Boat - CS-36T
vB code is On
Where's My Mooring? DrB General Discussion (sailing related) 1 05-27-2008 12:28 AM
Mooring systems GoodOldBoat Gear and Maintenance Articles 3 10-09-2007 10:05 PM
Mediterranean Mooring John Kretschmer Seamanship Articles 0 12-22-2003 08:00 PM
The Mechanics of Mooring Mark Matthews Seamanship Articles 0 05-19-2002 09:00 PM
Page generated in 1.1259 seconds (74.52% PHP - 25.48% MySQL) with 15 queries
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
