Old 11-12-2008
drlove is on a distinguished road
Do you just use plain Sta-set or XLS for sheets then?
  #12
Old 11-12-2008
Sta-Set is pretty good...it depends on whether you want low-stretch halyards or not. If you have dacron sails, don't bother with anything better than staset.
  #13
Old 11-12-2008
CaptKermie's Avatar
CaptKermie is on a distinguished road
Well, there are different reasons folks have for different colored lines. I my case I have a blue hull, close to pacific blue therefore all canvas is pacific blue as are fenders and other accessories. Halyards and sheets are white whereas traveller lines and rollerfiurler are blue with white tracers and boomvang and topping lift are white with blue tracers and so on, you get the idea blue & white color theme throughout. I have seen boats with black trim on the hull & deck who use black & white color theme throughout the running lines. It helps differentiate the different lines as well as color coordinate everything. Yes, it is the Admirals boat too and it really shows on the interior.
  #14
Old 11-12-2008
blt2ski's Avatar
I've got generally speaking blue for the main, green for spinaker, red for jibs, other colors of appropriate line for other tuning/reefing for the main etc.
Along with the appropriate cam cleats marked with what they are for etc too.
It helps the admiral, she like things color coded, and the interior is really nice as Kermie points out too.
I am using XLS extra extra? the lowest stretch of the three options for halyards, and sheets, lower grade for none stretch needs. Then I am now running carbon or one step below sails all around too!
Marty
She drives me boat,
I drives me dinghy!
  #15
Old 11-12-2008
I am going to go with a low stretch halyard choice to replace a wire to rope halyard setup (yes I know about checking the sheaves and halyard exit points). I will use a low stretch line so I can go smaller diameter. However for sheets, smaller diameter is not necessary and since the lines are handled more frequently, larger lines are usually more comfortable. Plus the sheets are not nearly as long as a halyard so combined with a shorter length plus larger diameter for handling, needing a high tech line to control stretch is not so much of an issue. I am leaning towards Crystalyne for halyards and XLS for sheets.
  #16
Old 11-12-2008
mangomadness's Avatar
mangomadness is on a distinguished road
I ordered my running rigging from Halls spars. They gave me an even better discount than what is listed. With a little research you can buy scrap cordage from this hyperlink for a fraction of the price. Some places may offer better deals on cordage, but not likely. I am no way affilated with them, I'm just passing on a good find.
Hall Spars & Rigging | Scrap Rope
  #17
Old 11-12-2008
J36ZT is on a distinguished road
The only line that I've ever seen a specific color given has been boomvangs. This line is almost always black with some colored tracer. Otherwise, the only purpose in having different colored lines is for rapid identification, especially useful when you have novice crew.
Skipper, J/36 "Zero Tolerance"
  #18
Old 11-12-2008
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
I kept it simple, sheets are Red w/white specks, halyards are white w/ red specks
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
  #19
Old 11-12-2008
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
So there's no difference between main, jib, or spin halyards. Interesting, I can't do that with the monkeys I sail with. They need colors.
Merit 25 # 764 "Audrey"
  #20
Old 11-12-2008
My little monkeys are use to our last boat, Sheets were green w/ white specks, Halyards were white w/ green specks
Lots of colors and things that shine, are bad ju-ju for my crew
1978 Tayana 37
You may post attachments
You may edit your posts
Gaff rigg / throat halyard question lbdavis Learning to Sail 5 09-11-2008 02:27 PM
C380 Asym Halyard Question tazcaptain C380 1 08-13-2008 07:24 PM
The Basics of Reefing Mark Matthews Learning to Sail Articles 0 03-29-2004 07:00 PM
Hold That Line Tom Wood Gear and Maintenance Articles 0 10-03-2002 08:00 PM
Rereaving the Main Halyard Dan Dickison Racing Articles 0 02-11-2002 07:00 PM
SEO by vBSEO 3.6.1
