11-12-2008
Having had the same problem - I would first error on the side of the temp of the engine compartment when starting. I was having really rough times starting and now preheat the engine, as temps have cooled a bit in the PNW and it starts ok now. Everything from replacing injectors, the starter, redoing the electrical etc can be advised but first try handling temp first. Even on my F-350, I plug in the OEM heater on cold days as it gets to be a beast to start...Its the cheapest solution when its all said and done but not knowing your location maybe indicates something else...
-- Jody
S/V " To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. " - 1983, Barberis Show 38! or To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
