11-14-2008
Gemini 105Mc Hull 987
10 ah a day would be 15 days to fully recharge from a 50% drain with no other source of charge (mooring or no generator).
Powering a (48v) 30amp motor with 150ah of usable battery gives you 5 hours of run time, and if you are day sailing you'd need roughly a hour or less to just get out and sail (location dependent of course).
That 30ah for a day sail would be replaced in 3 days. Doing it twice on a weekend cruise plus minus overnight drain for house circuits (I run 40ah on average, but that's at 12v, you can call it an additional 10ah equivalent) and you'll be pretty much good to go week after week, if everyday is sunny enough to get you 10ah, 100% efficiency etc.
If the motor takes more than 30ah, adjust your throttle, run time etc.. and you'll be fine. Make sure you don't go short on system monitoring (meters).
Note normally I'm as anti-electric motor as it gets, for me this is a very positive post
