Old 11-12-2008
tausap is on a distinguished road
Question Exhaust hose fitting question
I am replacing a very short section of 1.5" exhaust hose on my Fischer Panda AC generator. The section is only 6" long and runs vertically between the heat exchanger and the metal exhaust exit inside the soundproof case. Because it is such a short section of hose, it does not bend much. Does anyone have a good easy way to get the new hose on both ends without taking apart half the generator? I can't get the hose over the lip on either the upper or lower fitting due to the fact that it is off to the side too much overlapping the other fitting. Here is a depiction of how it should fit:
o o
o o < Metal exhaust
[o o]
[ ] < exhaust hose (1.5" x 6")
[o o]
o o
o o
o o < Lower metal fitting which exits the casing
o o o
o
ooooooooooo
Edit: It did not come out the same when published as I drew it to look, but maybe you can get the picture
Brett
S/V Liberty
1980 Morgan 461
Old 11-12-2008
sailboy21's Avatar
sailboy21 is on a distinguished road
boil it in hot water for a minute...
Old 11-12-2008
Don't boil it... that can cause the hose to deform permanently... do pour hot water over it...
Old 11-12-2008
sailboy21's Avatar
Yeah, SD is probably right for the wire hose. Temp range for Shields exhaust hose with wire is -20 to 200F. The no-wire stuff says intermittent at 250F is ok. But the silicone stuff max temp is 350F.
Good Source For Hose Fittings? SEMIJim Gear & Maintenance 15 07-23-2008 03:09 PM
Which caulking to use for exhaust hoses? bwindrope Gear & Maintenance 16 06-09-2008 01:24 PM
Caution using wire reinforced water hose NauticalFishwife Gear & Maintenance 3 04-09-2008 09:21 PM
Exhaust mixing elbow I-33 Gear & Maintenance 2 12-02-2006 03:24 PM
Atomic 4 exhaust dlahlers Gear & Maintenance 1 10-18-2001 01:18 PM
