Furling Line Hardware -- A New Option - Page 2 - SailNet Community
Blogs
  #11 (permalink)
Old 11-14-2008
You can still pull the insert free by tightening the screws...it is a lousy design and Harken knows it.
Originally Posted by Omatako View Post
The advantage of these blocks is that they're mounted outboard of the stanchion so the preesure of the line pushes against the stanchion and doesn't pull on the screws.
These are sweet blocks, I might have a look at them for our boat.
  #12 (permalink)
Old 11-14-2008
Irrationally Exuberant
arf145 is on a distinguished road
I installed the Garhauer stantion blocks for for our furling lines this past summer and I love them. Clunky? Not to my eye. I think the stainless construction of the Garhauer blocks blend in nicely with the stanchions. No plastic on them--I don't see them breaking any time soon.
arf145
1987 Pearson 28-2
Chesapeake Bay
  #13 (permalink)
Old 11-14-2008
artbyjody's Avatar
artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
The most important aspect of furler systems is how well you can pull the sail under load. Your stanchion blocks - how they are configured are the most important aspect of the design.
It has nothing to do with "you welt your legs" aspect. If you are welting then you are not sailing properly!
Lotsa of comments on using winches etc, all wrong using winches on furling lines period!!!!...Never!!
simple solution...
run the fairleads outside the stanchions for best mechanical advantage...It is where they should be actually. You get a better angle for starters...
Secondly you keep the deck clear.
The last stanchion block should be 45 degrees to point of incident. IE: 45 degrees to where you pull. It will stick out a hair but provide you the man handling leverage to pull in the genny / jib without using the winch. NEVER EVER use a winch to pull out the furler line... trust me - many $$$$
It either works or it does not and when it does not, it is human error not a result of the furler..Usually wrapped halyards at top of mast of mast or no slack in the tacking leads..
-- Jody
S/V "
1983, Barberis Show 38! or
  #14 (permalink)
Old 11-14-2008
JohnRPollard's Avatar
Moderator
Originally Posted by artbyjody View Post
...It has nothing to do with "you welt your legs" aspect. If you are welting then you are not sailing properly!
I guess I did not make that point clearly.
Our furling system worked perfectly fine.
The problem was the propensity to clip our ankle bones on the old inboard clamp-on blocks while traversing the side-deck -- usually while docked or anchored.
  #15 (permalink)
Old 11-14-2008
Jody-
JRP was "welting" his ankles... the older Schaefer blocks were at the perfect height to do that and stuck out just far enough to do so regularly.
  #16 (permalink)
Old 11-14-2008
christyleigh's Avatar
christyleigh is on a distinguished road
Wimp - Heck a little bruising and bleeding makes the classic "tearing up $100 bills while taking a shower" description of Sailing all the better ....... Just what I needed another excuse to spend a couple hundred more on the boat ......
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
  #17 (permalink)
Old 11-15-2008
GaryHLucas is on a distinguished road
Ah, I miss the days when I was a GOOD Harken customer. I bought over 100 18 foot long mainsheet traveler tracks and 150 mainsheet cars in one pop, then bought a slightly smaller quantity a short time later. They didn't go on boats, they went on greenhouses! I could get my own boat hardware added on to the orders for some really good discounts!
  #18 (permalink)
Old 11-16-2008
Omatako's Avatar
Omatako will become famous soon enough
You can still pull the insert free by over-tightening the screws...it is a lousy design and Harken knows it.
How did over-tightening something become the manufacturer's fault. Given that philosophy, a big enough tool will find fault with any design.
Arthur C. Clarke
  #19 (permalink)
Old 11-16-2008
wchevron's Avatar
Detachable member
wchevron is on a distinguished road
john, couldn't you have flipped the blocks so they were sticking outboard?
wchevron
s/v Time Flies
'78 C-30
  #20 (permalink)
Old 11-16-2008
Cerveza's Avatar
Cerveza is on a distinguished road
Can anyone answer me what is the benefit of running the furlig line like this?
I had a similar setup on my boat when I purchased it, but I changed it after a while and moved the line up to the left "cockpit winch" instead. I felt it has worked better for me. Now I have a proper rope clutch for it and so on (there was only a clam cleat for it to begin with)..
The pictures arent perfect for illustrating, but you should be able to see the furlig line to the left on the top picture, and over the cabin (trough the rope clutch and around the left "cockpit winch") on the lower picture.
Unbreakable Furling Line... MedSailor Gear & Maintenance 17 05-22-2008 07:18 PM
Roller Furling Line jr438234606 Gear & Maintenance 13 03-26-2008 12:43 AM
Adapting from the Match Race Crowd Dean Brenner Racing Articles 0 11-14-2001 08:00 PM
Broken Furling Line rrrr Gear & Maintenance 3 08-01-2001 03:20 PM
Avoiding Being Over Early Dan Dickison Racing Articles 0 06-24-2001 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
