Old 11-13-2008
sailboy21's Avatar
sailboy21 is on a distinguished road
Encapsulated keel:chunk missing.
Got the boat dried out today. Positioning was a little different than last time, and revealed this. I knew I had to have done some damage when I hit a reef about a year ago. Sure enough... Good news is I got my thruhulls fixed, the paint is holding up and there are no blisters...
So, given winter is fast approaching and humidity is 100% here year round a haul out and wait to dry method would be useless. Unless I could get it into a heated garage there is no point right now. So, until I sail to Mexico what should I do? My old friend "Splash Zone" comes to mind. This stuff would at least seal it up and prevent more seawater from wicking in to the laminate. I will leave it ugly so I know where it was. Sound like a plan??? Any other products that might work better?
Thanks all for any advice you have. I am floating off tomorrow at noon so whatever is done by then is done for an indefinite period.
Old 11-13-2008
sailboy21's Avatar
Old 11-14-2008
KeelHaulin's Avatar
STARBOARD!!
KeelHaulin will become famous soon enough KeelHaulin will become famous soon enough
I would grind it back a bit to feather the edges; paint in some fast setting epoxy and then as soon as it is tacky mix up some epoxy putty and use it as a fairing compound. Put plenty of epoxy putty on and then when it sets sand off the excess and paint.
Old 11-14-2008
sailboy21's Avatar
Good idea but its wet! I ended up putting the cans of splash zone in front of the oil heater until they were nice and warm to the touch. I took a bucked of hot water down, cleaned up the wound a little bit, splashed some hot water on her and went to work. It seems to have worked, was set nice and hard in the morning.. but..
Now: I have a real reason to go cruising. "Hunny, I need to sail to Mexico to haul the boat for a bottom job." So many layers of old paint on the old gal.. ick...
Old 11-14-2008
KeelHaulin's Avatar
STARBOARD!!
Not sure why you were worried about wetness? Is there water leaking from the hole? Oh well no matter since you have patched it and it is already back in the water.
When I was saying you should grind it back some I meant that you should grind back until you get to dry fiberglass; then paint in resin and then patch with epoxy putty. My thought about using the resin was to wet out the glass and form a surface that the putty could more easily bond to.
Old 11-14-2008
chucklesR's Avatar
Gemini 105Mc Hull 987
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
Marine stores sell 2 part epoxy putty that sticks to wet, plaster it on, smooth it out, paint it and splash it.
Old 11-14-2008
sailboy21's Avatar
I could have ground the entire keel away before I found a dry spot... There was a lot of exposed mat that has been soaking up water for the last year. No telling how far it went. I think it would be difficult to get a conventional epoxy to stick or cure under the conditions. Just not the environment to do any real glass work. Temperatures below 40, rain etc etc... I was just happy the splash zone fully cured...
Old 11-14-2008
Believe that MarineTex is one of those Two-part epoxies that will stick to wet surfaces.. even cures underwater IIRC.
Old 11-15-2008
Rockter will become famous soon enough
That's not a bad one there Sailboy.
A deep fin keel may not have weathered it so well.
Old 11-15-2008
sailboy21's Avatar
What? You mean they don't just bounce off rocks at 6 knots?
BTW: In British Columbia don't aim for the marker!
Searchers continue looking for 3-year-old missing after sailboat ... - The State NewsReader News Feeds 0 06-09-2007 10:15 PM
Search resumes for 3-year-old boy missing after sailboat capsizes - WIS NewsReader News Feeds 0 06-09-2007 07:15 PM
Search resumes for 3-year-old boy missing after sailboat capsizes - WHNS NewsReader News Feeds 0 06-09-2007 03:15 PM
Coast Guard continues search for missing sailboat - WLOS NewsReader News Feeds 0 05-10-2007 02:15 PM
Coast Guard continues search for missing sailboat - WLOS NewsReader News Feeds 0 05-08-2007 12:15 PM
