- Quick Menu
11-15-2008
Last Grumpy Old Sailor
Small, 2-Cond, Weather-Proof Connector?
Our compass is mounted on the mast. I'd like to get power to it to light it at night. Anybody have any suggestions for a small, 2-conductor, weatherproof connector I might mount in the mast, near the compass, to accomplish this? I've done a bit of research, but haven't found anything quite right.
Then I guess I'll need a small, also preferably weather-tight, in-line connector inside the mast, for when the mast is taken down.
Tnx,
Jim
s/v Abracadabra
1976 Pearson P30
11-15-2008
MSD 2-Pin Weathertight Connector 8173
11-15-2008
Thanks, bubb2. That looks like it'd work well for inside the mast, but I don't know as it'd work well for the connector through the mast.
Jim
s/v Abracadabra
1976 Pearson P30
11-15-2008
Jim are you speaking of a deck connector?
11-15-2008
Don't do it!!! I have never had luck with those.
What I have used on two boats, and has proven completely waterproof is the Aquasignal model. It is more than two connectors but it might work for what you are looking for. I use mine for a fish finder, but it used to power an autopilot. On my last boat I used it for the mast wiring with 100% success.
Its $40 but this thing really works. No metal to corrode or threads to gum up.
11-16-2008
I wouldn't use the WM one either... there are far better made ones..
11-16-2008
One technique that I have used very successfully is to glass a piece of PVC pipe through the deck. Run the wiring through it and make connections is a weather protected area below deck. Seal the wires in the pipe with a VERY generous amount of silicone sealant.
Remember this is not a frequently disconnected item. For a once a season disconnect, unconnect the wires at the below deck connector block, and simply pull them out the top. Reconnect with more silicone.
11-16-2008
This is a kludge IMHO... and silicone sealant has no place on a boat, other than covering the tips of cotter pins to protect the sails.
11-16-2008
LiittleMissMagic, Thanks for the lead, but, unfortunately, that site seems all but unusable for me. I guess it doesn't like Firefox or requires Flash or something.
sailboy21, Agreed: Those WM connectors don't look like what I want, anyway. Mast is curvy. Need a connector with a small footprint. Perhaps that Aqua Signal connector you've used will work. How are the pins connected to the wires? How is the connector base secured to its mounting surface? Aqua Signal's site is light on details.
gc1111, Gotta agree with SD on this one: *ick*. Sorry. Besides: We're talking about a really tiny wire, here.
Jim
s/v Abracadabra
1976 Pearson P30
| Thread Tools |
Search this Thread |
