New Battery charger (unplugged) causes spark on battery post!! - Page 2 - SailNet Community
post #11 of 16 Old 11-16-2008
A modest spark is normal when connecting many chargers to a battery. As one of the posters said, it's just charging up some sizeable capacitors.
If you were to leave it connected for a few seconds, or touch it to the battery terminal a few times, you'd see the spark diminish and disappear as the capacitors came up to full charge.
You'll like the Iota. IMHO it's the best one on the market for many marine setups. It's not the mickey mouse circuit one often finds...this one is RFI suppressed, frequency and voltage tolerant, has a true multi-stage operation (with the IQ4), including a periodic "equalization" stage, uses pulse-width modulation (PWM) technology which makes the batteries very happy, etc., etc.
I've got a 45A model sitting next to me here in the ham shack which maintains my bank of T-105 batteries which power all my radios. It runs 24/7 (for over 4 years, now). Another 55A model is on my boat dedicated to the T-105 bank which powers my windlass. It, too, runs 24/7 when at dockside. After several years, the T-105's test excellent with a sophisticated battery analyzer. By far the best battery charger I've ever used. And, at the current prices, an incredible deal!
Bill
btrayfors is offline
post #12 of 16 Old 11-16-2008
I'd second the Iota chargers. Got one for a friend's boat based on Bill's recommendation. Nice unit. IIRC, it's the same one you have...
sailingdog is offline
post #13 of 16 Old 11-17-2008 Thread Starter
Thanks for all of the help / advice! The charger is working great - Have watched to go from bulk - float and voltages tested great.
As mentioned, the spark was normal for connecting to batteries for the 1st time. Jut caught me off guard, and I am happy that I could check with you guys to confirm that it was normal, instaed of possibly ruining some equipment.
Thanks again.
On a related note. Eventually the charger will be installed on the boat, on a dedicated breaker, which I can shut off before disconnecting shore power.
However, since it is now just plugged into an AC outlet at the house, (house has older fuse panel rather than breakers), I just have to unplug it from the wall, if I want to shut it off, move it etc.
I will of course get a small spark as I pull the plug from the AC outlet, as it will be drawing current at the time. I have noticed this while unlpugging a running shop-vac as well, instead of turning it off 1st. Can any possible damage occur doing that, or it the spark so minor it is "normal / acceptable"??
Northeaster is offline
post #14 of 16 Old 11-17-2008
Larus Marinus
Idiens's Avatar
If you are doing it often, it would be worth fitting a proper switch that's designed to break circuits. But occasionally, no problem.
Jonathan-Livingston
Idiens is offline
post #15 of 16 Old 11-17-2008
Northeaster,
No need to unplug it at all; leave it plugged in. My 45A Iota which maintains my T-105s for the radios has been plugged in for over 4 years now, except for the occasional unplug when I needed the receptacle for something else.
As Idiens said, no harm if you unplug it occasionally.
Just be sure to check the water level in your batteries occasionally, being sure that the plates are covered. Use ONLY distilled water if they need some to cover the plates to about 3/8" above them.
Bill
post #16 of 16 Old 11-17-2008
I have a Guest 6 amp charger and battery maintainer which does the same thing. Been using it for about 6 years with no problems.
mlsalwa is offline
Building a Rudder Newport 30 Armchairprotest Gear & Maintenance 5 04-07-2009 01:11 PM
Electrical Problem - Newbie Not Sure Where to Start wolfmt Gear & Maintenance 32 07-14-2008 09:17 AM
A Little Help from the Sun Don Casey Gear and Maintenance Articles 0 12-20-2001 07:00 PM
A Little Help from the Sun Don Casey Cruising Articles 0 12-20-2001 07:00 PM
