  #11 (permalink)
Old 11-17-2008
If the head is forward, the raw water seacock for it is also likely forward, not back in the engine compartment.
Originally Posted by ckgreenman View Post
This was my thought. If the boat is equipped with a true marine head it's probably pulling raw water as well.
  #12 (permalink)
Old 11-17-2008
ckgreenman's Avatar
AFOC Stinkus Potus
ckgreenman will become famous soon enough
Send a message via AIM to ckgreenman Send a message via MSN to ckgreenman Send a message via Yahoo to ckgreenman
Key word being "likely". I remember the raw water intake for my Dad's Chris Craft was back by the engine even though the head was quite a bit forward.
The only way to figure out what it's for is to follow it. Head or water maker are the only things I can think of that would use raw water. Most sinks and showers (at least that I have ever used) use fresh water.
Chris
S/V "The Jade Dragon"
1975 O'Day 25
Meet me at
Ignore Power = Currently Rebuilding
  #13 (permalink)
Old 11-17-2008
Plenty of boats have had salt water galley sink intakes, either hand or electric pumps, for rinsing dishes, or even for washing them, to conserve fresh water supplies for drinking/food preparation.
1984 Fast/Nicholson 345
  #14 (permalink)
Old 11-17-2008
Especially if the boat was outfitted for long distance cruising, since the water in most harbors is rather nasty...
  #15 (permalink)
Old 11-17-2008
Ham1sh is on a distinguished road
At the risk of being overly simple, I suggest that the second through-hull is to drain galley sink water. It is on my boat.
  #16 (permalink)
Old 11-17-2008
ckgreenman's Avatar
AFOC Stinkus Potus
Assuming it's above the waterline. The way it was described I think the seacock in question might be below.
Chris
1975 O'Day 25
Meet me at
  #17 (permalink)
Old 11-17-2008
ckgreenman's Avatar
AFOC Stinkus Potus
Kinda like the water at RV parks. We always hooked up a 2 stage filter between the water supply and the hook up.
Chris
1975 O'Day 25
Meet me at
  #18 (permalink)
Old 11-17-2008
Given that it was described as being beneath the engine... I'd guess it was below the water line.
  #19 (permalink)
Old 11-17-2008
A below-water-line seacock will still drain a sink, as long as the bottom of the sink itself is above the waterline!
  #20 (permalink)
Old 11-17-2008
scottyt is on a distinguished road
on my hunter 27 the head intake is under the v berth starboard side, right next to the off shore holdng tank pump out. the sink has a large valve behind the galley cabinet under the cockpit. i have the hunter plumbing drawings and mine matches the drawing. i wonder if someone added a salt water rinse for the sink, how many faucets does your boat have? the only seacocks are the head flush and over board pump under the vberth, and the raw water intake under the engine per the drawing. the other must be added
No raw water flow after attempt to winterize - What happened Pamlicotraveler Gear & Maintenance 19 01-23-2008 07:13 PM
Cooling Water Reduncancy.... DrB Gear & Maintenance 10 08-12-2007 11:09 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
Water Ballast/Manufacturer RSJ Boat Review and Purchase Forum 6 03-07-2002 05:59 PM
