01-02-2009
Perkins 4-108
I have a 1985 Perkins 4-108 which I repainted about 10 years ago. I'm getting ready to do it again and may use the blue paint that was closer to the original color. What I did in the past was to wire brush and sand it as much possible, then applied a degreasing spray purchased at a auto parts store and then used a high temperature paint from a spray can. Not sure it was neccessary to go with the high temperature rating, but it sure has done well over the years. Do you know the temperature rating of the paint you're using?
