Coupling Bellows - SailNet Community
Blogs
Old 11-18-2008
ashley_nathan's Avatar
S/Y Tosca
ashley_nathan is on a distinguished road
Send a message via Skype™ to ashley_nathan
Question Coupling Bellows
Does anybody know where I can find a replacement bellows (not sure what you call it maybe collar, housing, its the rubber concertina tube that covers the universal coupling to the shaft and holds all the grease in) mine has a hole in it and has just made a lovely greasy mess up the walls of the engine bay.....
thanks
ashley
Old 11-18-2008
JHJensen's Avatar
Marine: Educator,Surveyor
JHJensen is on a distinguished road
Send a message via Skype™ to JHJensen
Fleixble coupling/Aquadrive ??? Need a bit more info..
Ashley,
Sounds like you have a flexible coupling or drive on your vessel....Some pictures and year,type of vessel and egine make would be helpful along with your location.
It sounds like you might have an Aquadrive... but am not sure w/o some more information.
J
"It's not just about the vessel... more importantly it is about the people, their safety and their vessels in that order. "(PFJ 1952-1986)
Old 11-19-2008
S/Y Tosca
hi J,
thanks for the Aquadrive suggestion, I've checked on their website and it is exactly what it is....should now be able to find the bellows for it.....thanks
ashley
Old 01-18-2009
S/Y Tosca
hi,
I now have the bellows, any suggestions on how to fit it.....
Rusted/Seized shaft coupling jarod Gear & Maintenance 4 04-29-2008 09:25 AM
Flexible bellows exhaust connection FishSticks Gear & Maintenance 7 11-17-2007 10:42 AM
Shaft coupling loose bolts Edo Kazumichi Gear & Maintenance 8 11-24-2006 10:51 AM
Flexible shaft coupling zerubb Gear & Maintenance 1 08-19-2006 12:13 AM
prop shaft coupling kurt crowley Atomic 4 2 06-27-2006 04:45 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
