12-18-2008
You should also check your shorepower cord, right at the shorepower inlet on the boat and and where it plugged into the AC source.
Originally Posted by janders
Judging by the number of question marks you used, there's clearly a large difference between oil radiant and oil radiator.  My bad. Yep, oil radiator. The only thing I worry about with the heater is the power cord and plug. I run my hand along it every day to see if it's generating any heat. So far, so good. I also bungee the cord so it doesn't lay on our settee. I don't want it slipping behind the cushions.
