Steaming light - Page 2 - SailNet Community
post #11 of 14 Old 11-24-2008
Glad I found Sailnet
Bene505's Avatar
Originally Posted by mdbee View Post
You can make either light work with only two wires, some diodes and a double pole double throw switch
True, but as Sailboy21 says, "However the deck light is not a navigation light, therefore you should be able to operate it completely independent of any other lights on the mast."
So the diodes with 2 exesting wires will do if he doesn't want to do any re-wiring. Running some 3 conductor wire would be better to allow use of the deck light while steaming. (Or to allow use of the decklight while sailing, if he uses a 1-diode method for a choice of "steaming" or "both".)
Bene505 is offline
post #12 of 14 Old 05-16-2009
is there any problem for those of us who can't really run new wiring due to logistics/time, etc., to run it so that the deck & steaming light are both on at all times when it's switched on?
Obviously when sailing you can't then properly use the deck light ...
But is there a regulatory or safety problem/issue with having both on when underway under power?
Thanks,
Jon
S/V Catalyst:
Pearson 26 #1200
fendertweed is offline
post #13 of 14 Old 05-17-2009
mitiempo's Avatar
On a really dark night the foredeck light would not help your night vision in my opinion.
mitiempo is online now
post #14 of 14 Old 05-17-2009
good point ... that was my first thought & concern ... if I replace I'll stick w/ a standard steaming light.
Jon
S/V Catalyst:
Pearson 26 #1200
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 02:23 PM
Tri-color Steaming masthead light as only nav light? Perithead Gear & Maintenance 110 09-18-2011 01:53 PM
Light Lists, Lighthouses, and Visible Ranges Jim Sexton Seamanship Articles 0 06-19-2003 09:00 PM
Light Lists, Lighthouses, and Visible Ranges Jim Sexton Her Sailnet Articles 0 06-19-2003 09:00 PM
Performing in Light Air Brian Hancock Learning to Sail Articles 0 01-15-2003 08:00 PM
