Old 11-23-2008
wchevron's Avatar
Detachable member
wchevron is on a distinguished road
Steaming light
i'm thinking of replacing my mast steaming light with one of these allied signal steaming/foredeck lights. looking online, the documents say it takes 2/3 wires. would that mean one load wire for the steaming, one load for the foredeck and a common neutral and they would be controlled by different breakers? or is it on one breaker and the whole thing comes on all at once. i currently i only have 2 wires up the mast.
wchevron
s/v Time Flies
'78 C-30
Old 11-23-2008
Except that this is DC, so there is no "neutral", as you suggest these fixtures use two positive, separately switched wires (one per bulb) and use a common negative ground.
It seems you will need to pull in a new cable or add a wire.
1984 Fast/Nicholson 345
Old 11-23-2008
W...
I have that light too.
The one common is the negative, then I have one switch for the deck light and another one for the forward light.
But in my previous boat, I had only 2 wires, and both lights were on all times.
Old 11-23-2008
billangiep's Avatar
billangiep is on a distinguished road
Using the mast as your ground you could use the two existing wires as your positive leads.
You start sailing with a bag full of luck and an empty bag of experience. The idea is to fill the bag of experience before you empty the bag of luck.
Old 11-23-2008
timebandit's Avatar
timebandit is on a distinguished road
If your two current wires are for your anchor lite then you will have to pull at least 2 more wires and use a common ground, four wires in all.
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
Old 11-23-2008
badsanta is on a distinguished road
How long is your boat??
Old 11-23-2008
thekeip is on a distinguished road
That particular light fixture can be wired so as to require only two wires to work either light.
Howard Keiper
Berkeley
Old 11-23-2008
sailboy21's Avatar
sailboy21 is on a distinguished road
No No No!!! Never use your mast as a ground except maybe for a lightening protection system)
Run new wire. 3 conductor is fine. Common ground and 1 pos for each light switched separately somewhere. You don't want them both coming on at the same time, But you also don't need a separate breaker. Just two toggle switches.
Here is what the most basic schematic should look like for a fixture like that (fuse or breaker should be sized based on the instructions for the fixture):
If space is a limiting factor (like on my panel, didn't feel like re-engineering the whole thing) when I needed more switches I ended up putting things like the tricolor and bow lights, and anchor and steaming light on the same double position (SPDT) toggle switch, center being off, since you would never have the anchor & steaming light, or the bow & tricolor on at the same time. However the deck light is not a navigation light, therefore you should be able to operate it completely independent of any other lights on the mast.
Old 11-23-2008
I'd agree that you shouldn't be using your mast as a ground. It can cause some serious problems with current induced galvanic erosion on underwater parts.
I have that same fixture installed on my boat, and it should be fine for yours.
Old 11-23-2008
Large Member
mdbee is on a distinguished road
You can make either light work with only two wires, some diodes and a double pole double throw switch
LEDs afloat GoodOldBoat Gear and Maintenance Articles 18 8 Hours Ago 03:15 PM
Tri-color Steaming masthead light as only nav light? Perithead Gear & Maintenance 110 09-18-2011 12:53 PM
Light Lists, Lighthouses, and Visible Ranges Jim Sexton Seamanship Articles 0 06-19-2003 08:00 PM
Light Lists, Lighthouses, and Visible Ranges Jim Sexton Her Sailnet Articles 0 06-19-2003 08:00 PM
Performing in Light Air Brian Hancock Learning to Sail Articles 0 01-15-2003 07:00 PM
