Old 11-23-2008
Jcod12 is on a distinguished road
maintenance costs
what are the maintanence cost on a salboat per year... rough estimate?
- Saltwater
- Living on board
- 26-30 ft.
- Jason
Old 11-23-2008
bubb2 has a spectacular aura about bubb2 has a spectacular aura about bubb2 has a spectacular aura about
! million or so give or take!!!
This is my new boat
2004 VT Shipbuilding Sail Boat For Sale - www.yachtworld.com=
Can you give us some idea on what kind of boat you are speaking of.
Old 11-23-2008
dhornsey is on a distinguished road
We generally budget around $200/month for maintenance projects, on an older 31 foot liveaboard sailboat. Then every now and then there's a real BIG month
A lot depends if you are doing improvements or just taking care of problems as they occur.
Pacific Seacraft Mariah 31
Old 11-23-2008
tomaz_423's Avatar
tomaz_423 will become famous soon enough
Bubb, a million seems a lot to me for 26 - 30 feet LOA.
Could be adequate if 30 feet is draft.
Beneteau Oceanis 473
preparing to sail away
Old 11-23-2008
Are we talking wood, steel, fiberglass? What kind of condition is she in now? What problems are you starting with? how old is the boat?
Old 11-23-2008
The situation is i am looking to buy my first sailboat, and i am wondering how much i should expect to pay to maintain a seaworthy fiberglass sailboat between 26 and 30 ft in length. My budget is between 10,000 and 15,000.
Is it possible to find an open ocean, seaworthy boat for this price?
when you say 200/mo, what is that going towards?
how often do you repaint a saltwater fiberglass boat? costs?
any recommendations for what boat i should be looking for?
thanks!!
Jason
Old 11-23-2008
sailboy21's Avatar
sailboy21 is on a distinguished road
No need to keep up with the bottom paint. Just sail it regularly and do touch ups now and then. Dive & scrape. Yes you can get 10 years from a good bottom job...
Seaworthy boat for that price? Yes. Contessa 26 comes to mind. Rawson 30's of course. Older Columbias, Cal's, Pearsons etc...
$200/month... you wish. There isn't really a 'monthly' cost. Just really big ticket items you should either plan on or budget for.
A new bottom every 5-10 years will cost you $4k on a 30 footer.
New engine every 1000-5000 engine hrs. About $12K.
New rigging every 5-15 years: $4K.
new Sails every 5-20 Years: 4K.
New running rigging 2-5 years: 1K
Batteries every 2 years: 1K
These are the biggies, and estimates quite on the high side. Always plan on the simplest things costing at least twice, perhaps up to 10 times their actual cost. Running a single bilge pump wire this spring ended up in a complete rewiring of my entire boat. In other works a $10 job ended up costing around $400. Of course you can bargain hunt and dumpster dive, but a "new" set of used sails will still cost you 25% of an actual new set but you will have to replace them 4-5 times as often and you will be less satisfied... You can get a used or rebuilt engine but it is still going to cost thousands... etc etc... Just my take.
Conceivably you could buy a boat for $10K, put about $5K in upgrades, shove off for a few years and spend little to nothing on maintenance. Then dump it when you are finished and you are out nothing. Plenty of people sailing about using that method.
Edit: I have some videos that show you what a Rawson would be like to sail, click here. You can get these boats, or similar older boats, in the price range you are looking for that will take you anywhere you want to go. With the economy sucking so bad you can get really good deals.
Old 11-23-2008
Yes, you can possibly find a bluewater capable boat for that price, but it will require quite a bit of shopping around to get one in good condition. I'd highly recommend you look at James Baldwin's list of pocket bluewater crusiers. It is located HERE.
I would recommend getting a boat in decent shape for $10000 or so and using $5000 to re-fit, upgrade and repair the boat.
That goes to hauling out, maintenance and cleaning supplies, etc. If the boat is need of work, the number will be much higher.
It depends. If the topsides, deck and cabin top were painted, then you'll have to maintain it... if it is gelcoat and in good shape, you just have to wash and wax it. The bottom may have to be painted every other year or so, depending on what antifouling paint you use. If the woodwork is varnished... then you'll be having to maintain that regularly.
thanks!!
Jason
See James Baldwin's list above.
40' vs 45' maintenance costs 6string Boat Review and Purchase Forum 19 02-05-2008 11:27 PM
Reducing Exterior Maintenance Sue & Larry Gear and Maintenance Articles 0 10-15-2003 08:00 PM
Annual Maintenance costs leonardje Gear & Maintenance 0 11-12-2002 11:37 AM
caribbean maintenance costs zchill Gear & Maintenance 1 06-29-2002 06:34 AM
What should I budget for annual maintenance costs? DuaneIsing Gear & Maintenance 21 06-05-2002 11:58 AM
