Old 11-26-2008
soulesailor's Avatar
blue collar cruiser
soulesailor is on a distinguished road
Originally Posted by bubb2 View Post
If I understand what you are saying, I wonder how you can release a tether that clips to your back?
Notice in the photo in the link on the front of the vest is a buckle with a little 3" cord coming out of it. Pull on the cord, the buckle unclasps and the wide webbing pulls out all the way around back and slips easily through the ring on the tether. The buckle does not release itself even under a lot of abuse, until you pull the release cord.
Edit: I just noticed the picture in the link shows the buckle and webbing strap in the frontal picture but in the back the webbing is not in the photo. The webbing goes all the way around the vest and this is how you attach it to the ring on the tether on the back.
who is staring at the sea is already sailing a little
  #12
Old 11-26-2008
bubb2 has a spectacular aura about bubb2 has a spectacular aura about bubb2 has a spectacular aura about
Ok, I see that now. It might work for inland sailing but not the type of vest I would want to be wearing if I went over in big water.
  #13
Old 11-26-2008
erps's Avatar
the pointy end is the bow
so if I understand it correctly you would have a line, or you could use webbing, with a loop spliced into each end permanently looped around the the jackline. When you want to hook in just grab the other end loop and hook into the quick release.
Yes, that's what I was thinking. I was thinking of maybe using Amsteel line as tethers all over the place. Small, light, abrasion resistant and strong. Could have it in bulk on the boat and make up as many as one would want and replace them when they start getting fuzzy.
I see a bigger issue to this set up. In really extreme weather you do not ever want to be unhooked while on deck. The usual set up is to have two teathers, on the D rings so you can go from anchor point or jackline to the next anchor point or jackline without ever being unhooked.
Good point. I hadn't thought of that.
While this might work well for you, it would cause you some issues if you have people crewing for you that don't have the same type of harness modification you do.
Hadn't thought of that either.
Thanks for the feed back guys.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
  #14
Old 11-26-2008
TxLnghrn's Avatar
Ignoring Trolls in 2009
TxLnghrn is on a distinguished road
TXLNGHRN—
What if your boat turns turtle... if you don't have a quick release and have gloves on sailing in colder waters... you might not be able to get the tether detached quickly enough. You really do need a quick release on the body side of any safety tether. Anything that can not be released under load is a serious danger.
Thanks for the feedback SD, I will have to give this system some more thought and perhaps some trial runs. I was thinking that if the carabiner gets put under load it should go onto the long axis allowing me to open the gate and slide the tether or the d-rings on my vest out. Perhaps I'll hang myself from the mast and give it a try. Great sailing weather still here but a little cool to be dragged behind the boat.
Michael
S/V Anything Goes
1987 Pearson 31-2
Hull #15
  #15
Old 11-26-2008
There is a reason the current tethers and harnesses are designed the way they are... they weren't developed in a vacuum.... but in real-world conditions, and to maximize safety and usability. If you guys can come up with something truly novel that is as easy to use and as safe, you might make a mint... but I don't see it happening any time soon.
  #16
Old 11-26-2008
blue collar cruiser
Yes, obviously. I can't figure out why they insist on buckles on the front though. Why is this?
  #17
Old 11-26-2008
erps's Avatar
and product liability and profit margins and marketing appeal.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
  #18
Old 11-26-2008
jrd22's Avatar
Courtney the Dancer
To solve the problem of transferring from one point to another without ever being unhooked you could have two quick releases attached to the harness, hook onto the new one and then release from the other. Requires two QR's though.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
  #19
Old 11-26-2008
tommays's Avatar
So i have to think
How people get saved from going overboard buy the harness compared to going down with the ship because of the harness
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
  #20
Old 11-26-2008
It is hard to claw your way up the tether to the boat, if the tether is clipped to your back.
You may post attachments
You may edit your posts
Safety Harnesses and Tethers John Rousmaniere Gear and Maintenance Articles 0 05-06-1999 08:00 PM
Safety Harnesses and Tethers John Rousmaniere Cruising Articles 0 05-06-1999 08:00 PM
SEO by vBSEO 3.6.1
