Knotmeter reads - SailNet Community
post #1 of 4 Old 09-04-2002 Thread Starter
Knotmeter reads
I have a "new" 1988 C30. It has Std. Horz. depth and speed mounted at the helm. The speed reads "0.0". The paddlewheel is free and I''ve turned it 180deg. with the same results. Is there a way to check the paddlewheel output? I hate to just buy another unit only to still see "0.0"
Thanks in advance!
Mike in Noank
dargiem is offline
post #2 of 4 Old 09-04-2002
Knotmeter reads
I am no expert but..have you traced the wiring for proper conection? If so, is your gage dual reading, meaning does it show distance also? If it does take the boat for a short sail and see if it registers distance, if so you may have a fault with the speed portion of the gage.
cptmyway is offline
post #3 of 4 Old 09-06-2002
Knotmeter reads
I just went through this problem with a B&G Horizon on a "new" boat. There is a magnet in the sender; test it with a paper clip. The specs for a B&G are 170 Ohms resistance across the leads of the sender unit. Get the specs from Standard Horizon and do a test with a VOM.
ammcguire is offline
post #4 of 4 Old 09-07-2002
Knotmeter reads
My old Datamarine goes on strike (0.0) about once or twice every time we are out. Then returns to functioning after its union negotiated break times. Another oddity is that the miles log unit is set in statute not
nautical miles.
halyardz is offline
GPS vs Knotmeter skyamsen Gear & Maintenance 13 12-26-2011 07:13 PM
KNOTMETER FOR 81 PEARSON FLYER MAYHEBLESS Gear & Maintenance 1 06-13-2001 09:46 PM
Unknown knotmeter odyssey23 Gear & Maintenance 0 04-12-2001 02:03 PM
Knotmeter for Catalina 30 kevinmhulse Gear & Maintenance 0 03-14-2001 08:49 AM
