Old 09-04-2002
cptmyway is on a distinguished road
Roller Furling problems
I have a 1978 CT42'' Ketch with roller furling on the head sail and cutter sail. Twice I have had the furling line come loose from the drum (OLD HOOD SYSTEM)and I had to re-wrap the line with the drum fixed in place while underway. Is there a way to make the drum free wheel rather than hand wrap the intire line?
  #2
Old 09-04-2002
Sailmc is on a distinguished road
The real question is why did the line come loose. Did it break or did the knot slip? This should not ever happen. If it comes off re-wraping it is the only way to put it back on.
  #3
Old 09-04-2002
True enough, first reason, old line on boat when I bought it broke at drum, second time lack of experience with furlers and tied an improper knot. But the original Q was answered, Thanks
You may post attachments
You may edit your posts
Mariner Roller Furling jkoutras Gear & Maintenance 12 02-06-2013 11:20 PM
Hyde Roller Furling gaurre3 Gear & Maintenance 13 08-01-2010 08:16 PM
Mechanical difference between roller furling and reefing? duffer1960 Gear & Maintenance 6 10-26-2009 09:46 AM
Roller Furling Dan_T Gear & Maintenance 6 11-02-2001 11:14 AM
Roller Furling stewpee Gear & Maintenance 1 05-30-2001 04:59 PM
SEO by vBSEO 3.6.1
