12-03-2008
I guess it is attached from inside the boat and pushes the bearing out toward the prop.
I did a quick web search for a '68 Islander 33 but didn't find one so I'm not sure if your boat is a full keel. From your statement, I suspect that it may be. If so, then the press won't work as far as I know.
For fin keeled boats with a spade rudder, the press attaches forward of the prop strut with an attachment on the aft side to hold it. It looks something like a pipe cut in half with a hydraulic ram. I can't find a photo of it in use.
For a full keeled boat, I'm not sure how the bearing would be extracted. It's possible that it can be used from withing the boat, but it's best for a yard to determine. If so, the labor shouldn't be much.
Good luck. Sorry if I misled you.
Sabre 38 "Victoria"
