12-01-2008
If the brush is clean of grit and has soft bristles, it shouldn't scratch the acrylic noticeably.
However, I would recommend using a polycarbonate, like Lexan or Makrolon, with an anti-scratch/UV-resistant coating instead of glass or acrylic, unless you can get fairly heavy laminated tempered glass cut to the right shape for the ports on your boat. Chances are likely that the "glass" isn't actually glass, but acrylic of some sort. Polycarbonate is far stronger and breakage resistant than acrylic.
