Pumping out - Page 2 - SailNet Community
post #11 of 33 Old 12-03-2008
Baybilly
Spiritman's Avatar
Second dog's idea.
I have the same setup as he does with an Edson diaphragm pump that will clear the shyte from a thirty gallon holding tank in about a minute. The exhaust from the tank goes to a Jabsco lockable Y-valve that directs the flow to the deck fitting or over to the pump. I've installed a check valve between the Y and the pump to help with the priming. It's worked perfectly for the past six years.
Spiritman is offline
post #12 of 33 Old 12-03-2008
I installed a tee in the pump out hose between my holding tank and the on deck pump out port. Then I put a good diaphram pump between that tee and a new thru hull with no Y valves anywhere. No second holding tank pump out hose. The thru hull is closed unless pumping overboard and with a closed thru hull, the shore based pump out works fine too. I think an antisyphon loop is important.
scosch is offline
post #13 of 33 Old 12-03-2008
Don't believe an anti-siphon loop is necessary, since the vented holding tank should act as a siphon break.
sailingdog is offline
post #14 of 33 Old 12-07-2008 Thread Starter
pumpout
I LIKE it, Scosch! Simple. What kind of pump do you use? And is the thru hull above or below the waterline? Call me crazy but I subscribe to the Pardy's paranoia about thru hulls.
perfecttempotim is offline
post #15 of 33 Old 12-07-2008
sailboy21's Avatar
Here is a little trick. Put the thruhull just under the normal waterline, maybe about 1-2" That way it is hidden from normal view, but there are no embarrassing streaks running down the side of the boat... The way mine is positioned I can actually change the ball valve with the boat floating in her slip Kind neat to look down into the mushroom and see water just sitting there. But only do that on a CALM day!
sailboy21 is offline
post #16 of 33 Old 12-07-2008
I believe it was a "Domestic" (probably imported, ha) Sanipump, diaphram type, from WM. WM also carries a Whale pump with similar specs. The important factor was that it was made (so they say) for waste and wouldnt burn out if run dry accidentally. I originally considered a macerator type pump but they have a reputation for burning up when run dry and although cheaper, one replacement would nullify any savings. I figured by the time the waste had traveled thru all the hoses, the holding tank and the pump that it would be almost "macerated" anyway.
Yes the thru hull is below the water line, but not much. Seems like it belongs below the water line for reasons mentioned. Im not frightened of correctly installed thru hulls.
And Im not convinced that you dont need a siphon loop between the tank and thru hull but it may depend on your installation. Seems to me like the holding tank vent is not in the correct place to solve the problem and is not anymore useful than an open container would be in stopping siphon action. I defer to greater experience but I would think that part through.
scosch is offline
post #17 of 33 Old 12-07-2008
mitiempo's Avatar
The only thing that the anti-siphon loop would do (if between the holding tank and the through hull) would stop the holding tank from back-filling with water. The holding tank would be pumped out only periodically anyway. When not actually pumping it out you would close the seacock and would have to for the deck pumpout to have suction.
mitiempo is offline
post #18 of 33 Old 12-08-2008
sailboy21's Avatar
Some heads are below sea level at certain angles of heel. If there was a failure in both the flapper valves in the pump and in the head all at the same time it is conceivable you could flood your head... But since you would be sailing at the time hopefully someone would notice! I don't know any setup where a seawater flushed toilet is mounted below normal sealevel, even on Navy ships. That just seems like an entirely bad idea.
post #19 of 33 Old 12-08-2008
Hi Tim
We went to the Bahamas with a Tartan 27 and the holding tank only held 12 gals.We used a gusher pump with a very long hose on the discharge end(Could double up if sinking and reach the cabin with swapped ends and still pump while sailing) and a fitting that fitted the deck outlet.This we used when in deep water or only on a strong ebb tide in an anchorage. The hose was then rinsed by pumping sea water through it ,no problem and cheap.Ellinor from Keldee
Keldee is offline
post #20 of 33 Old 12-08-2008
Siphoning would depend on the dip tubes. the only way water could bypass the vented tank would be to siphon though the inlet and out the through hull. The holding tank inlet would have to be below the level of liquid in the tank for this to be possible, but it would go in and straight out. System would be no different than the sink drain, filling to whatever the waterline is.
It might even do a little flushing.......
boofus is offline
Bilge Pumping System Design TheWastedYears Gear & Maintenance 7 09-26-2008 11:09 AM
need help quick... MAST vibrations bristol321 Gear & Maintenance 12 01-02-2008 09:08 AM
Oil change Problem TJC1010101 Gear & Maintenance 22 11-10-2007 06:00 PM
Pumping the Bowl Dry theArchitect Gear & Maintenance 10 06-15-2007 12:32 AM
Pumping out a flat bilge Jonathan316 Gear & Maintenance 7 07-19-2005 02:03 AM
