- Quick Menu
12-02-2008
Pumping out
I have a holding tank without the ability to pump overboard. We hope to move aboard and cruise in areas where there are no pumpout facilities. I prefer not to drill another through-hull and install a pump. I'm trying to find a way to pump out while off shore, directly from the deck fitting. Any suggestions? i found something made by LeeSan in the UK but it is very expensive, even before shipping.
There was an interesting article in the latest Practical Sailor about composting toilets but we had bad experiences with one all last summer on an island in Maine.
Tim
12-02-2008
Moderator
Do you have the ability to direct discharge from your toilet? If not, that would be an important upgrade for sailing in areas with no discharge regulations (like off-shore). It's far preferable and simpler to pump directly out rather than through the holding tank.
12-02-2008
Pumpout
No, I don't have direct pumpout from the head. I'm not planning any big passages anyway and I do not want to foul the place where I sleep--so to speak--regardless of regulations.
BTW your Pacific Seacraft is one of my favorite boats. If I hadn't bought a catamaran I would've gotten a PS.
T
12-02-2008
Moderator
T
Hey , thanks for the boat compliment.
As for the discharge -- I think your best bet will be to bite the bullet and add another thru-hull for direct discharge from the toilet while off-shore. You can also add a y-valve that will alternatively send the toilet offal to the holding tank directly. You can then plumb a pump-out hose at the bottom of the holding tank, connect it to an electric or manual macerator pump, then to the new thru-hull for discharge.
I guess I'm just not keen on trying to pump out the holding tank through the deck fitting while sailing off-shore. You could end-up in a real pinch if conditions were too rough to do that (assuming you can find a feasible way), and then you are dealing with an unusable toilet and bursting holding tank while simultaneously coping with heavy weather. Not a pleasant combination!
12-02-2008
Gemini 105Mc Hull 987
Tim,
hate to say it but the through hull fittings are basically your only choice. Creating a system where you literally suck it out through the deck fitting sounds easy until it breaks at sea, or you have 3 feet of green water on deck for 3 days before it finally rips your improvised fitting off and sinks you and the boat in a pool of poo.
Since you have to do it anyway, do it right and have a direct overboard fitting put in with a y valve that makes it selectable to pump to the tank or overboard, and another valve that allows you to gravity drain your holding tank via the direct overboard through hull. It's just one hole and, two valves and some hose - but DO NOT stint on the quality of the hose it has to be sanity (impermeable) rated, and rigid so you can pump it/create a suction without collapse. Should not run more than 300 bucks or so and you can do most of it yourself.
12-02-2008
I think it is a better idea to plumb the head directly into the holding tank, and then plumb the pump out hose of the holding tank to a diverter valve, with one leg going up to the deck fitting and the other going to the seacock and through hull, using a diaphragm pump or macerator pump to allow you to dump the holding tank overboard.
This setup minimizes the amount of plumbing and the complexity of the head as much as possible, while giving you the most flexibility overall. Yes, you lose the ability to directly pump the head overboard, but any place you could dump the head directly overboard, you would be able to pump out the holding tank, so no real loss of utility. Also, this allows you to keep the large seacock for the head system closed most of the time, minimizing any risk of the head back siphoning and such.
12-02-2008
San Juan 26
T
Don't worry too much about that. Whales, fish, crabs...they all poop in the ocean.
Jon Caisson Bozeman
S/V Little Miss Magic, Pirates Cove, AL
12-02-2008
My boat came with a diaphragm pump that tees off the deck pump out and tees into the sink drain. I know it sounds gross.. but... There is a ball valve directly under the sink. If I close that, pump the tank out through the sink drain thru-hull, and then flush lots of water through it isn't bad at all. Then close the holding tank suction valve, slowly vent the valve under the sink and its all done.. whew... This was very useful cruising through Canadian inside passage where there is NO pumpout facilities anywhere. I don't like the overboard option at anchorages either. I tried to wait for the open water sections before I pumped...
Here is what the system looks like:
I added the valve downstream of the pump so I can lock it shut for legal purposes. The waterline is about right at the top of the holding tank relative to everything in the diagram. From the toilet I can also pump directly overboard via a two-way valve, or pump to the tank where I then get the choice of pumpout at the dock or pump overboard at sea. The normal positions of the valves are shut and shot for the red ones, open for the blue. I can pour water or RV antifreeze into the deck fill to clean out the pump.
Note that the user MUST do the steps properly. Notice that if you don't shut the valve under the galley sink and start pumping there is a very good chance you will fill the sink with poo and pee... this is a very important step to take
After pumping you must shut the holding tank suction and pump discharge or risk filling the holding tank with seawater that leaks by the flapper valves in the pump. While this wouldn't sink the boat it is still a very important observation to make.
I have my suspicions that this isn't going to be "approved" by some sailnetters. All I can say is I didn't do it. Wouldn't have done it, but its there and it works... so...
12-03-2008
Wharfinger
Gag reflex
I've pumped out a holding tank, by hand, through the deck fitting, once. It was memorable but not enjoyable. I've seen a couple on another boat take turns doing it between gagging. The big question is; What do you do with the fittings, pump and hoses after you're finished? They would not be welcome anywhere on my boat after they were used once.
My current boat's head discharges directly to a 40 gallon holding tank. From the tank there is a Y-valve which selects between the deck fitting or, via a hand pump, to a thru hull. The thru hull is about 18" below the waterline.
My old boat's head discharged directly overboard, with the thru hull about six inches above the water line. This had less risk of flooding, but attracted frowns whenever the head was used in a quiet anchorage. Suprisingly, it always washed clean and I never saw any stains or residue on the white hull below the thru hull. An above waterline thru hull could be an option if you don't want another hole below the waterline.
12-03-2008
I've plumbed my last two boats with the same set up, recommended to me by Ocean Link, based in Rhode Island. The head goes straight to the holding tank, no Y valves. The tank has one discharge line to the deck fitting, one discharge line to a pump for overboard discharge. This system works great, no extra parts to fail. The other beauty of this system is the tank design. All hoses enter the top of the tank and are connected to PVC pipe that internally goes to the bottom - they call them dip tubes. This prevents sewage from standing in the hose - a major source of bad odor.
Good luck.
Skywalker
| Thread Tools |
Search this Thread |
