diesel fuel - Page 4 - SailNet Community
post #31 of 31 Old 12-05-2008
1. A tank is a closed system in that once air is drawn in and beomces cold it no longer draws in air!!! Outside of the tank is an open system. Air with moisture is cooled loses it's moisture and then falls downward only to be replaced by new warm moist air. THIS does not happen inside the tank. Second how would fuel moving around inside the tank pump air in and out???? Another problem is that the inside of a boat should be warmer than the outside air. Just think. It gets dark and the air cools off but the inside of the boat stays warm longer than outside. The air inside a tank deep in the sailboat should be warmer than the outside air. So any air drawn inside the tank should be cooler than the air already in the tank ie the air warms up when it comes inside the tank. Next day when it is warmer outside any air flow will be out of the tank as the inside of the boat warms up. Also if the boat is in the water the inside of a closed boat will never get much colder than the water. On a cold night the boat is warmer than the air outside!!!! Again the physics don't work!!!!!
MoonSailer is offline
Bleeding your Yanmar Engine artbyjody Gear & Maintenance 41 09-23-2016 11:03 PM
Filtakleen Ten 35 fuel additive??? Gas & Diesel T37Chef Gear & Maintenance 15 06-23-2014 12:32 AM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Diesel Fuel Concerns SailNet Gear and Maintenance Articles 0 07-08-2002 08:00 PM
