Can you winterize an engine without running it first? - Page 3 - SailNet Community
Blogs
  #21 (permalink)
Old 12-05-2008
Rockter will become famous soon enough
Bucket next time then. I must have got lucky about 5 times then. I did not start the hose until the motor was running and did not stop the motor until the hose was stopped. I guess it must depend on the rate of delivery.... the was a choke fitting on the end of the hose.
I did contaminate the motor with water when a coolant O-ring failed, and things got rather mustardy. A pump out and about 2 oil changes, and a long run, and the motor was OK... at least the oil was transparent. The water does boil off in the end. I have seen it do so on motorcycles.
  #22 (permalink)
Old 12-05-2008
M275sailer's Avatar
M275sailer is on a distinguished road
How would you winterize if you were unable to start the motor for some reason?
Boat-Mirage 275
Port-Killarney
Bleeding your Yanmar Engine artbyjody Gear & Maintenance 27 08-17-2009 08:32 AM
water in engine oil?!?!? msbam207 Gear & Maintenance 20 08-22-2007 03:45 AM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 08:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 08:00 PM
Safety Check Mark Matthews Her Sailnet Articles 0 01-25-2000 08:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
