Vinyl Boat Graphics - Page 3 - SailNet Community
Blogs
  #21 (permalink)
Old 12-08-2008
scottyt is on a distinguished road
i did my own, cost was 10 bucks. there is a sign shop 2 blocks from me, cost of the material was 10 bucks, then i found a font the wife liked i printed the letters out then cut it out with a razor blade. including cutting and applying time was about 2 hours. most of that was bouncing in the dingy on the hook with the waves let me see if i can find a pic
edit with pic
  #22 (permalink)
Old 12-08-2008
blt2ski's Avatar
I used goof off to remove the painted lettering on my boat, which is ONLY availible from Lowes, as they bought the rites to it! I want to say acetone will work, then again it could be mineral spirits, which is similar to goof off.
I had a local sign shop to the vinyl lettering for my boat, then again, they did the lettering or my biz trucks too.
marty
She drives me boat,
I drives me dinghy!
  #23 (permalink)
Old 12-08-2008
rikhall's Avatar
old guy :)
rikhall will become famous soon enough
Originally Posted by Leither View Post
I recently used Doityourselflettering.com and can recommend them for price, quality and quick turnaround.
Stuart
Stuart
Did you buy the regular or the Do-It-Yourself weeding and tape option ?
Thanks
Rik
Irwin Citation 34
  #24 (permalink)
Old 12-08-2008
rikhall's Avatar
old guy :)
There has not been much in the regular "adhesive" world that has not come off with WD 40. Really! Got Duct tape sticky - WD 40, got that black builders acoustic stuff they put around windows - WD 40 even takes labels off wine bottles that I want to re-use - just rinse real well!.
And no - I own no stocks in WD 40 nor in Duct tape - I wish I did.
A boater friend of mine always says "Duct tape is like the Force. It has a light side and a dark side, and it holds the universe together."
Cheers
Irwin Citation 34
  #25 (permalink)
Old 12-08-2008
heinzir's Avatar
Junior Senior
heinzir is on a distinguished road
Talking
Duck Tape and WD40 are the only tools you really need to fix anything. If it moves and isn't supposed to, Duck Tape it! If it is supposed to move but doesn't, WD40 it!
Henry
Chiquita - 1974 Macgregor Venture of Newport 23
  #26 (permalink)
Old 12-08-2008
retclt's Avatar
Roadkillibus Texanis
retclt will become famous soon enough retclt will become famous soon enough
Naptha is basically the same thing as Goof off. Charcoal lighter fluid the same. Goof Off just smells prettier.
Bob T
"I cannot not sail" - E. B. White
  #27 (permalink)
Old 12-08-2008
RAGTIMEDON's Avatar
RAGTIMEDON is on a distinguished road
To remove either painted or vinyl lettering from your hull Goof- off, lighter fluid, charcoal lighter will all work, but probably take more rubbing than easy-off oven cleaner or Drano. Acetone will attack the fiberglass. The first three are organic solvents, poisonous to fish and other marine animals, and flammable. They do not mix with water, but float on top. Most hardware store paint removers will attack fiberglass, and the bottom paint removers made for fiberglass are expensive. Oven cleaner and drain cleaner are strong caustics, will attack your skin, require rubber gloves while using them. However, they will dissolve and disperse in water and react with any acid substance in the water so they leave no detectable or poisonous residue in the water. Drano and most other drain cleaners will run, whereas Easy-off oven cleaner is thick and will stay in place to soften the paint. IMHO oven cleaner is the preferred choice! I have used it, it works well!
Don
1980 Endeavour 37 sloop, currently in the Mississippi near St Louis
  #28 (permalink)
Old 12-09-2008
WouldaShoulda's Avatar
AEOLUS II
WouldaShoulda is on a distinguished road
To remove the painted on name, use Easy Off Oven Cleaner... provided your hull isn't painted... The area under the letters will appear slightly different in color to the rest of the gelcoat, but the difference should fade with time.
We brought vinegar to the party and it cleared up the yellowing right away.
Apply, rest, remove, rinse, vinegar then rinse again.
The unsighly residue will be gone and the boat will stop smelling like a sub sandwhich in just a few days!!
  #29 (permalink)
Old 12-09-2008
funsailthekeys is on a distinguished road
I used vinyl lettering on the stern 23 years ago and it still looks good.
Making Passage w/o a Rudder wind_magic Seamanship 60 07-16-2010 02:23 PM
help with lifes dream kimby Boat Review and Purchase Forum 37 12-03-2009 12:32 AM
Naming and Renaming Your Boat Sue & Larry Cruising Articles 0 12-15-2003 08:00 PM
Fine-Tuning the Autopilot, Part Two Dan Neri Gear and Maintenance Articles 0 10-13-2003 09:00 PM
Performing in Light Air Brian Hancock Learning to Sail Articles 0 01-15-2003 08:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
