Butyl tape questions. - Page 2 - SailNet Community
post #11 of 12 Old 12-09-2008
Courtney the Dancer
jrd22's Avatar
David is right, McClendons in Renton has it, just picked up a role today. It's in weatherstripping section, they have gray and black.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #12 of 12 Old 12-09-2008
Follow this link to a tech sheet on Sabre's site. it will show you how to rebed the lexan into the aluminum frame and then how to use a combo of Butyl tape and caulking. Even if you don't have a Sabre, most of these frames are similar.
http://www.sabreyachts.com/pdf/RebedSabre28.pdf
I just completed this project, it came out great and I have a dry boat, at least for now.
After removing the interior screws, I used a dull putty knife and a razor knife to separate the frame from the boat and a lot of rubbing to remove whatever the last person used to caulk the window in. It is important to have a clean surface before you add the tape. One other thing, be sure to put painters masking tape around the opening before you add the caulking, it really makes clean up a lot easier.
Good luck.
JLBJR
JLBJR is offline
Window gasket sealant.. groundhog Gear & Maintenance 39 07-11-2014 03:27 PM
Ryobi vs. Makita vs. Poliglow?? CLucas Gear & Maintenance 61 05-05-2012 06:02 AM
butyl tape pegasus1457 Gear & Maintenance 53 04-30-2009 05:58 PM
Three ways to fix dodger windows GoodOldBoat Gear & Maintenance 2 11-05-2008 05:37 PM
Butyl Tape fer hardware sealing fun! Skipper Joe Gear & Maintenance 10 04-18-2008 12:33 PM
