Trojan verses AGM - Page 2 - SailNet Community
post #11 of 13 Old 12-09-2008
moderate?
camaraderie's Avatar
Originally Posted by xort View Post
My boat has had batteries under the bunk since 1985, as designed by the factory. Am I about to die?
Thanks
No...but it does explain some things about you Ed!
Vent it anywhere you like. The whole idea is just to get some air flow in there so there is no accumulation of vapor.
camaraderie is offline
post #12 of 13 Old 12-09-2008
BTW, Hydrogen is pretty good at escaping... Helium isn't as active and look at how it does from sealed mylar balloons. You probably don't need a whole lot of venting for a battery box...as long as the vent is at the top of the box... Hydrogen rises...fairly rapidly.
sailingdog is offline
post #13 of 13 Old 12-09-2008
Trojans are not the only choice for wet acid batts.
Interstate makes 225Ah. 6V that are pretty good also. They hold more liquid are heavier and have better construction.
I've had six of them in my Endeavour 32 for 8 years now maintained only by my AirX turbine...they lasted 8 years and I wasn't very nice to them. I bought 2 Rolls Surrette 8D's because I got them for a song at CE Beckman's.
But I was pleased with the Interstates.
And...There is no such thing as a "maintenance free" batt.
windship is offline
Equalizing AGM batteries Shelgail Island Packet 25 02-27-2016 06:59 PM
AGM Batteries Yofy Gear & Maintenance 10 08-16-2007 02:33 PM
SeaVolt AGM vs. Lieline AGM gilsurf Gear & Maintenance 7 08-06-2007 11:00 PM
SeaVolt 800 Starter battery...add AGM..? marinesniper Gear & Maintenance 4 01-03-2007 10:36 AM
Mixing AGM and wet cell batteries Jonathan316 Gear & Maintenance 7 06-21-2005 10:16 AM
