Old 12-08-2008
endreholen is on a distinguished road
Universal M25 Overheating - Puzzling symptoms
Hi there,
I have a Catalina 30 with a Universal 25. It overheats pretty quickly on startup.
When I feel the hoses going to and from the heat exchanger, there is no heat and flow it appears.
However, when I pull the thermostat out of the thermostat housing, the engine stays cool and I can feel warm water going into the heat exchanger.
The thermostat is new and opens just fine when in hot water.
So not sure what is going on here!
Any tips?
Old 12-08-2008
timebandit's Avatar
timebandit is on a distinguished road
The thermostat isn't in backwards is it?
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
Old 12-08-2008
newpbs is on a distinguished road
Water Pump?
Is your water pump moving enough water? Perhaps when you remove the thermostat the decreased resistance allows the pump to move more water and cool the engine better. I'd check the pump, if the thermostat checks out.
Paul
Old 12-08-2008
Yeah, I thought about the thermostat being backwards. However, it only fits one way and also checked the engine diagram/parts manual.
This whole thing started with a water pump that was shot so have a brand new pump in there.
I do wonder if I have enough circulation/flow. What is the best way to check that?
Endre
Old 12-08-2008
drlove is on a distinguished road
Do the thermostats come in different temperature ratings? Perhaps yours needs to open at a lower temp than the one you have.
Old 12-08-2008
swadiver's Avatar
swadiver is on a distinguished road
E,
I had a similar problem with the Universal 25 on my Catalina 30. I started at the impeller and worked toward the heat exchanger. Disconnect a hose and turn the engine over with the kill switch on, to see if I had any flow. In my case the impeller was ok, but i had rock like deposits built up in the o/p from the impeller housing. I cleared those and thought I was home free and when I pulled the hose going into the heat exchaner, good flow. When I pulled the hose going out of the exchanger, hardly any flow. My Heat Exchanger was bad. I could not boil it out and ended up installing a new exchanger. Problem fixed. Good luck.
Scott
Long Beach, Ca.
s/v Namaste - 86 Catalina 30 , Tall Rig
The optimist expects the wind. The pessimist complains about the wind. The realist adjusts the sails.
Old 12-08-2008
Rockter will become famous soon enough
If the problem was the heat exchanger, would it stay cool with the thermostat out? I think not.
If it truly is overheating (is the temp guage into the red?) then the thermostat is not allowing the primary coolant to get to the exchanger, or (less likely) the primary coolant pump is not beating the restriction of the thermostat.
Are you sure that it is truly overheating? Is it gurgling and boiling when you shut it down? Make sure you keep your primary coolant topped up until the problem is sorted. Be careful not to get poached by a steam escape from that primary coolant header tank opening cap. I have seen the aftermath of it once from a steam escape from a car, and it was a horrible injury. Be careful. Your primary coolant is pressurised, and very hot. Let her cool well down first.
I wish this one was local.
It's not in NE Scotland, is it? Perhaps not.
Old 12-08-2008
Leither's Avatar
Retired and happy
Leither is on a distinguished road
The approach suggested by Swadiver seems like to way to go. However, I would try another thermostat (and check the rating) before you start removing pipes etc. I would still be suspicious of it, since the engine ran cool when it was removed.....
Good luck
Stuart
Leith (rhymes with teeth) is the port of the City of Edinburgh in Scotland. A Leither is someone who comes from that area.
I must go down to the sea again, to the lonely sea and the sky - I left my shoes and socks there, I wonder if they're dry?
Old 12-08-2008
It is puzzling. It is overheating with the gauge in the red and lots of steam and gurgling right around the thermostat. But not in the header tank of course... It is really really weird. I will double check to see if I have the right thermostat.
Is there a way to figure out if the pump works well?
Old 12-08-2008
erps's Avatar
the pointy end is the bow
Which pump did you replace? The raw water pump or the fresh water pump on the motor?
Now that is wierd. I wonder if the coolant isn't all the way topped off and there is a big air pocket between the engine and heat exchanger.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Overheating Universal 5411 JohnBassett Gear & Maintenance 20 05-20-2009 11:54 AM
Dangerous Seafood Ralph Doolin Seamanship Articles 0 03-20-2003 07:00 PM
Dangerous Seafood Ralph Doolin Cruising Articles 0 03-20-2003 07:00 PM
Dangerous Seafood Ralph Doolin Her Sailnet Articles 0 03-20-2003 07:00 PM
