Old 12-08-2008
DrB DrB is offline
DrB is on a distinguished road
Seacock Base for 1/2" thru-hull "pipe"
I have one of these as my thru-hull for my Raw Water intake for my motor. It's a 1/2" Bronze Intake Strainer.
The PO had put on a Marlon 1/2" shut off valve that worked okay, but the handle eventually sheered. I talked to the PO about it to see if he had any bad luck with the Marlon valve before and he also had one sheer on him. He suggested that he probably should have gone with a proper seacock set-up, but the Marlon worked well for him for a year or two.
I want to convert over to a proper seacock set-up, with triangle base, and metal ball valve. The problem is I can't find a 1/2" adapter base to go from the thread pattern on the Intake Strainer Thru-Hull, to the thread pattern (NPT) on the ball valve. 3/4" is the smallest I can find.
Any ideas?
DrB
Old 12-08-2008
Maine Sail's Avatar
Make the whole thing
Make the whole thing 3/4" and ditch the 1/2" fitting. Many manufacturers have moved away from 1/2" fittings as they plug up very, very easily.. Depending upon where you are you might want a hinged screen. I have had that type plug before with eel grass and it's a royal PITA to clean it out. I no longer use a intake screen and instead increased the intake to 1" and it never plugs and it passes everything to the strainer thus preventing going over board with a knife to dig crap out of the slots....
______
-Maine Sail / CS-36T
Old 12-08-2008
I'd second what Maine Sail suggests...since cleaning out a strainer basket beats having to dive to clean out an external hull strainer every time. And a 1" through hull has four times the volume capacity of a 1/2" one...meaning that even if it does get a bit of growth in it, you'll still have plenty of water to cool the engine.
Ryobi vs. Makita vs. Poliglow?? CLucas Gear & Maintenance 61 3 Weeks Ago 06:02 AM
C & C 121 Customer Response to Manufacturers Post camaraderie Tartan 0 09-10-2007 06:43 PM
Spring Hull Cleaning Tom Wood Gear and Maintenance Articles 0 04-05-2004 08:00 PM
hull construction cgha33 Boat Review and Purchase Forum 4 05-23-2003 07:11 PM
