Old 12-09-2008
gtod25 is on a distinguished road
Cutting out an Aluminum fuel tank.....
I'm about to cut out a center line fuel tank, which has to be removed piece by piece. Not looking forward to the experience. I need recommendation about what tools to use. Sawzall won't work and grinder has not been recommended because the cutting disk gets loaded with aluminum.
Any ideas?
Thanks
Gerry
Old 12-09-2008
It might help to say what boat this tank is on, since someone may have prior experience with doing what you're about to attempt.
Old 12-09-2008
It might help to say what boat this tank is on.
Then again it might not?
Old 12-09-2008
bubb2 has a spectacular aura about bubb2 has a spectacular aura about bubb2 has a spectacular aura about
you might try.
DeWALT DW891 Heavy-Duty 14 Gauge Swivel Head Shear
Old 12-09-2008
GMarcus is on a distinguished road
Aircraft "nibbler"
Gerry:
You might try an aluminum "nibbler" usually used on aircraft/aircraft parts. It's strictly manual, but cheap but they also have air powered nibblers. It nibbles out about a .125" width kerf, but should work for what you intend doing..
Might look on Aircraft Spruce & Speciality's web site or Wag-Aero, etc.
Good luck,
Gary
Old 12-09-2008
retclt's Avatar
Roadkillibus Texanis
retclt will become famous soon enough retclt will become famous soon enough
SCORE!!!!!!!!
Consider a Silicon carbide cutting wheel. It's recommended for aluminum.
Here's a link with pretty good information.
Choosing The Right Grinding Wheel: MMSOnline.com
Bob T
"I cannot not sail" - E. B. White
Old 12-09-2008
timebandit's Avatar
timebandit is on a distinguished road
aluminum?
Skill saw with a carbide tipped blade should work just fine.
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
Old 12-09-2008
Rockter will become famous soon enough
Watch your heat build-up and fire risk. Resins catch fire quickly. Keep a hose nearby and make sure the water is switched on. Fill a bucket of water also and keep it nearby.
Old 12-09-2008
merc2dogs is on a distinguished road
nibblers or three jaw shears, Harbor freight sells them cheaply.
Better brands are better. They cut nice and quiet and leave a clean edge that's not as sharp as most other cutters.
Very little mess or noise.
Harbor Freight Tools - Quality Tools at the Lowest Prices
You can also pick up an attachment that works with a standard 1/2 inch drill motor.
they have three jaws and cut so the only real 'waste' is a narrow strip of metal that curls up nicely so you don't have to hunt down 10,000000 little half moon razor blades.
For aluminum, it helps if you put some dish soap along the cut line to keep the blades lubed up.
Ken.
Old 12-09-2008
captbillc's Avatar
ancient mariner
captbillc is on a distinguished road
RETCLT that is a great article about grimding wheels, thanks.
Liberals are people who care about others. Freethinkers are not constrained by the myths of religion.
Myth of Condensation in Fuel Tanks Martinini General Discussion (sailing related) 47 08-03-2009 01:22 PM
Life expectancy of aluminum diesel fuel tank jbrockpiano Gear & Maintenance 7 10-27-2008 03:26 PM
Replacing my fuel tank this Spring, and need your sage advice. ChicagoNewport27 Gear & Maintenance 12 06-04-2008 07:39 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
